Get started with Apache Arrow and Arrow Flight on Google Axion C4A
Create firewall rules on GCP for Apache Arrow, MinIO, and Arrow Flight
Create a Google Axion C4A arm64 virtual machine on GCP
Set up Apache Arrow and MinIO on arm64
Analyze columnar data with Apache Arrow on arm64
Run high-speed analytics with Apache Arrow Flight on arm64
In this section, you deploy Apache Arrow Flight, a high-performance RPC framework designed for analytics workloads. Arrow Flight enables zero-copy, memory-to-memory data transfer over gRPC, making it ideal for distributed analytics engines.
Arrow Flight enables zero-copy, memory-to-memory data transfer over gRPC, allowing analytical data to be shared between processes and systems without serialization overhead. This makes it ideal for distributed analytics engines, interactive query systems, and real-time data pipelines.
This section demonstrates how Arrow Flight works on arm64 (Axion) using a simple server-client setup on the same virtual machine.
Arrow Table (In-Memory)
v
Arrow Flight Server (gRPC)
v
Arrow Flight Client
What this architecture shows:
In this step, you create an Arrow Flight server that exposes an in-memory Arrow table to clients over gRPC.
Create a file named flight_server.py.
import pyarrow as pa
import pyarrow.flight as flight
class ArrowFlightServer(flight.FlightServerBase):
def __init__(self, location):
super().__init__(location)
self.table = pa.table({
"id": list(range(1000)),
"value": [i * 10 for i in range(1000)]
def do_get(self, context, ticket):
return flight.RecordBatchStream(self.table)
if __name__ == "__main__":
server = ArrowFlightServer("grpc://0.0.0.0:8815")
print("Arrow Flight server running on port 8815")
server.serve()
source arrow-venv/bin/activate
python flight_server.py
This terminal will block — this indicates the server is running and listening for client connections.
The output is similar to:
(arrow-venv) gcpuser@arrow-flight:~> python flight_server.py
Open another terminal on the same VM and check that the gRPC port is listening.
ss -lntp | grep 8815
If you see a listening process, the server is up.
LISTEN 0 4096 *:8815 *:* users:(("python",pid=4255,fd=7))
Now you connect to the Arrow Flight server using a client and retrieve the in-memory dataset.
Create a file named flight_client.py.
client = flight.FlightClient("grpc://127.0.0.1:8815")
reader = client.do_get(flight.Ticket(b"dataset"))
table = reader.read_all()
print(table.schema)
print("Rows:", table.num_rows)
python flight_client.py
value: int64
Rows: 1000
What this demonstrates:
In this section, you:
Next, review the Learning Path summary and continue with related Arm server analytics content in the next steps page.
