Get started with Apache Arrow and Arrow Flight on Google Axion C4A
Create firewall rules on GCP for Apache Arrow, MinIO, and Arrow Flight
Create a Google Axion C4A arm64 virtual machine on GCP
Set up Apache Arrow and MinIO on arm64
Analyze columnar data with Apache Arrow on arm64
Run high-speed analytics with Apache Arrow Flight on arm64
In this section, you prepare a SUSE Linux Enterprise Server (SLES) arm64 virtual machine and install the core components for high-performance analytics using Apache Arrow. You also deploy MinIO, an S3-compatible object storage service, to store analytical datasets in later sections.
This foundation ensures all analytics libraries are natively optimized for arm64 (Axion).
This architecture represents a single-node analytics environment that mirrors how modern cloud analytics stacks operate: compute and memory-local processing with object storage–backed datasets.
SUSE Linux Enterprise Server (arm64)
v
Python 3.11 Virtual Environment
v
Apache Arrow Libraries
v
MinIO (S3-Compatible Object Storage)
Install Python, build tools, and system libraries required by Apache Arrow and its ecosystem.
sudo zypper refresh ; \
sudo zypper install -y \
python311 python311-devel python311-pip \
gcc gcc-c++ make \
libopenssl-devel \
libuuid-devel \
curl git
python3.11 --version
The output is similar to:
Python 3.11.10
Why this matters:
Create an isolated Python environment for Arrow and analytics libraries.
python3.11 -m venv arrow-venv
source arrow-venv/bin/activate
pip install --upgrade pip setuptools wheel
Why this matters:
Install Apache Arrow and supporting analytics libraries.
pip install \
pyarrow \
pandas \
numpy \
s3fs \
grpcio \
grpcio-tools \
fastparquet \
pyorc
python - <<EOF
import pyarrow as pa
print(pa.__version__)
EOF
23.0.1
This confirms Apache Arrow is correctly installed on arm64.
MinIO provides high-performance, S3-compatible object storage, which is widely used in modern analytics architectures.
Download MinIO for arm64:
curl -LO https://dl.min.io/server/minio/release/linux-arm64/minio
chmod +x minio
sudo mv minio /usr/local/bin/
mkdir -p ~/minio-data
export MINIO_ROOT_USER=minioadmin
export MINIO_ROOT_PASSWORD=minioadmin
minio server ~/minio-data --console-address :9001
MinIO endpoints:
Leave this process running.
MinIO Object Storage Server
API: http://127.0.0.1:9000
WebUI: http://127.0.0.1:9001
Once logged in to the MinIO console, create a bucket that will store analytics datasets.
Open this URL in your browser:
http://<VM-IP>:9001
Login credentials:
MinIO Web UI displaying buckets and stored Parquet/ORC objects
arrow-data
MinIO Web UI displaying the arrow-data bucket
MinIO Bucket View
This bucket will be used to store:
In another terminal (same VM, virtual environment active), export S3 credentials so Python libraries can access MinIO.
export AWS_ACCESS_KEY_ID=minioadmin
export AWS_SECRET_ACCESS_KEY=minioadmin
export AWS_DEFAULT_REGION=us-east-1
Verify:
env | grep AWS
What this enables:
to communicate with MinIO exactly like Amazon S3.
In the next section, you will use Apache Arrow to write and read Parquet and ORC datasets from MinIO using vectorized analytics APIs.
