Analyze columnar data with Apache Arrow
In this section, you use Apache Arrow’s columnar execution engine to read and write analytical datasets stored in MinIO (S3). You will work with Parquet and ORC formats and explore predicate pushdown and column pruning, which are key performance optimizations in modern analytics engines.
This section demonstrates how Arrow delivers high-performance, vectorized analytics on arm64 (Axion).
Architecture overview
Python Analytics Scripts
        v
Apache Arrow Dataset API
        v
Parquet / ORC Columnar Files
        v
MinIO (S3 Object Storage)
What this architecture shows:
  • Compute and execution happen in-memory using Apache Arrow
  • Data is stored in object storage (MinIO) using open columnar formats
  • Only required data is read from storage, reducing I/O and latency
Write Parquet data to MinIO
In this step, you create a sample dataset in memory using Apache Arrow and write it to MinIO in Parquet format, the most common columnar format used in analytics engines.
Create a file named write_parquet.py.
import pyarrow as pa
import pyarrow.parquet as pq
import s3fs
table = pa.table({
    "id": list(range(1000)),
    "value": [i * 10 for i in range(1000)]
fs = s3fs.S3FileSystem(
    key="minioadmin",
    secret="minioadmin",
    client_kwargs={"endpoint_url": "http://127.0.0.1:9000"}
pq.write_table(table, "arrow-data/dataset.parquet", filesystem=fs)
Run it
source arrow-venv/bin/activate
python write_parquet.py
Verify in MinIO UI
Open the arrow-data bucket in the MinIO console. Refresh if needed. Select the “arrow-data” bucket. You should see “dataset.parquet” listed:
Image Alt Text:MinIO object browser showing dataset.parquet stored inside the arrow-data bucket alt-txtMinIO Web UI displaying dataset.parquet object in arrow-data bucket
What this confirms:
  • Apache Arrow successfully serialized in-memory data
  • Parquet files were written directly to S3-compatible storage
  • No local filesystem dependency is required
Read Parquet using Arrow Dataset API
Next, you read the Parquet dataset using the Arrow Dataset API, which enables efficient scanning, filtering, and projection.
Create a file named read_parquet.py.
import pyarrow.dataset as ds
import s3fs
    key="minioadmin",
dataset = ds.dataset(
    format="parquet",
    filesystem=fs
table = dataset.to_table()
print(table.schema)
print("Rows:", table.num_rows)
Run the reader
python read_parquet.py
The output is similar to:
value: int64
Rows: 1000
What this demonstrates:
  • Schema inference from Parquet metadata
  • Efficient columnar scanning
  • Fully vectorized execution on arm64
Predicate pushdown and column pruning
One of the biggest performance advantages of columnar formats is that queries can push filters and column selection down to the storage layer.
Create a file named filter_parquet.py.
import s3fs
    key="minioadmin",
    format="parquet",
    filesystem=fs
filtered = dataset.to_table(
    filter=ds.field("id") > 990,
    columns=["id"]
print(filtered)
Run the filter script
python filter_parquet.py
        pyarrow.Table
This confirms:
  • Predicate pushdown: Only rows with id > 990 are read
  • Column pruning: Only the id column is loaded
  • Vectorized execution: Processing happens in columnar batches
These optimizations significantly reduce I/O and CPU usage for large datasets.
Write ORC data to MinIO
In addition to Parquet, Apache Arrow also supports ORC, another popular columnar format widely used in Hive and Spark ecosystems.
Create a file named write_orc.py.
import pyarrow.orc as orc
import s3fs
table = pa.table({
    key="minioadmin",
with fs.open("arrow-data/dataset.orc", "wb") as f:
    orc.write_table(table, f)
print("ORC file written to MinIO")
Run the ORC writer
python write_orc.py
Verify in MinIO UI:
In the arrow-data bucket after refreshing, you should now see:
  • dataset.orc
  • dataset.parquet
Image Alt Text:MinIO object browser showing dataset.orc stored inside the arrow-data bucket alt-txtMinIO Web UI displaying dataset.orc object in arrow-data bucket
In this section, you have:
  • Written analytical datasets in Parquet and ORC formats
  • Stored columnar data in S3-compatible object storage
  • Used the Arrow Dataset API for efficient reads
  • Applied predicate pushdown and column pruning
  • Executed vectorized analytics optimized for arm64 (Axion)
This forms the core analytics layer used by modern engines such as Spark, DuckDB, Trino, and Polars.
In the next section, you will enable high-speed memory-to-memory analytics using Apache Arrow Flight, demonstrating gRPC-based data transfer, zero-copy serialization, and high-throughput analytics communication.
