Set up Apache Spark with Alluxio
In this section, you’ll connect Apache Spark to Alluxio and enable in-memory caching.
Without caching, Spark re-reads data from storage on each pass. With Alluxio in the path, frequently accessed data can stay in memory, which reduces repeated storage reads.
You’ll then measure the difference between uncached and cached reads.
Install Apache Spark
Download Apache Spark, extract it, and place it under /opt:
cd ~
wget https://archive.apache.org/dist/spark/spark-3.4.2/spark-3.4.2-bin-hadoop3.tgz
tar -xvzf spark-3.4.2-bin-hadoop3.tgz
sudo mv spark-3.4.2-bin-hadoop3 /opt/spark
sudo chown -R $USER:$USER /opt/spark
Configure Spark environment
Set the Spark environment variables so you can run Spark commands from your shell:
echo 'export SPARK_HOME=/opt/spark' >> ~/.bashrc
echo 'export PATH=$PATH:$SPARK_HOME/bin' >> ~/.bashrc
source ~/.bashrc
Connect Spark with Alluxio
Open the Spark configuration file and add the Alluxio filesystem implementation and client JAR paths:
nano $SPARK_HOME/conf/spark-defaults.conf
spark.hadoop.fs.alluxio.impl=alluxio.hadoop.FileSystem
spark.driver.extraClassPath=/opt/alluxio/client/alluxio-2.9.4-client.jar
spark.executor.extraClassPath=/opt/alluxio/client/alluxio-2.9.4-client.jar
These properties register Alluxio’s Hadoop-compatible filesystem implementation so Spark can resolve alluxio:// URIs. They also add the Alluxio client JAR to both the driver and executor classpaths.
Create a dataset
Create a sample dataset in /mnt/data/demo. Files placed in /mnt/data are accessible to Spark through the alluxio:/// URI prefix because /mnt/data is configured as Alluxio’s root underlying file system:
rm -rf /mnt/data/demo
mkdir -p /mnt/data/demo
The following loop generates 100,000 records, creating a small but representative dataset for the caching benchmark:
for i in {1..100000}; do
echo "record $i - alluxio spark learning" >> /mnt/data/demo/data.txt
done
Verify the file was created successfully:
wc -l /mnt/data/demo/data.txt
The output is similar to:
100000 /mnt/data/demo/data.txt
Start the Spark shell
Start the interactive Spark shell. This opens a Scala REPL with a pre-configured SparkSession available as spark. All commands in the following sections run inside this shell:
spark-shell
Welcome to
____ __
/ __/__ ___ _____/ /__
_\ \/ _ \/ _ `/ __/ '_/
/___/ .__/\_,_/_/ /_/\_\ version 3.4.2
/_/
Using Scala version 2.12.17 (OpenJDK 64-Bit Server VM, Java 11.0.30)
Type in expressions to have them evaluated.
Type :help for more information.
scala>
Load data via Alluxio
Load the sample dataset through the Alluxio namespace and confirm that Spark can read it successfully:
val df = spark.read.text("alluxio:///demo/data.txt")
df.count()
The expected output is:
100000
Enable caching
df.cache() marks the DataFrame for Spark’s in-memory caching. The subsequent df.count() triggers a full read, loading the data from Alluxio into Spark’s cache. After this step, repeat reads on df are served from Spark’s in-memory cache rather than going back through Alluxio:
df.cache()
df.count()
Measure performance
Run for the first time:
val t1 = System.nanoTime()
df.count()
val t2 = System.nanoTime()
println((t2 - t1)/1e9 + " seconds")
Run for the second time after caching:
val t3 = System.nanoTime()
df.count()
val t4 = System.nanoTime()
println((t4 - t3)/1e9 + " seconds")
Run both timing blocks and compare the printed values. The output is similar to:
0.44 seconds
0.39 seconds
The second run is faster because Spark serves the result directly from its in-memory cache. Spark bypasses Alluxio and the underlying storage entirely.
Verify in Alluxio UI
Open the Alluxio UI. Replace <VM-IP> with the public IP of your VM:
http://<VM-IP>:19999
Alluxio cluster load and worker utilization during processing
Alluxio data view displaying cached datasets
The UI shows files stored in Alluxio namespace. You can see cached files and directories available for fast access.
In the Alluxio Web UI, confirm the following:
- Increased worker memory usage in the worker summary
- Cached file blocks listed in the data browser
- Active data access reflected in the cluster metrics
What you’ve accomplished
You’ve now connected Apache Spark to Alluxio on an Azure Cobalt 100 Arm64 VM and loaded data through the Alluxio namespace. You measured the difference between an uncached and a cached read. You then verified the caching activity in the Alluxio Web UI, where worker memory usage increases and cached file blocks became visible after the first read.
To see the full performance benefit of Alluxio, you can replace the local disk UFS with a remote storage backend such as Azure Blob Storage. In that configuration, Alluxio caches data in local worker memory after the first read, eliminating repeated remote storage round-trips for subsequent Spark jobs.
