Explore related resources
    Give feedback
    AI-assisted
    Close
    How do I know that the web application started correctly?
    Check the startup output for the runner, cascade driver, text-path files, FFmpeg, and thread count checks. When the service is ready, it listens on 127.0.0.1:8000.
    How do I provide a reference voice sample?
    Use the browser application to record a sample or upload an existing reference recording. The application converts the audio to the format expected by the server runner.
    What result will I get after generating speech?
    The server returns a WAV file that speaks the provided text using characteristics of the reference voice. You can play the file in the browser or download it.
    How do I access the browser application on the instance?
    Create an SSH tunnel that forwards port 8000 from the instance to your local computer. Then, open http://127.0.0.1:8000 in your local browser. The application remains bound to the instance loopback interface and isn’t exposed on a public network interface.
    Can I run the model from the terminal instead of using the browser?
    Yes. The browser application is a FastAPI wrapper around onnx_tts_runner.py. You can invoke the runner directly from the terminal with the required inputs and model directory.
