Arm AI Portal
The Arm AI Portal is a catalog of AI models optimized for Arm-based targets across different runtimes, use cases, and profiles. The AI Portal provides benchmarking and compatibility data, code examples, and deployment methods.
You’ll use the Qwen3-TTS package from the Arm AI Portal to clone a voice on an Arm Neoverse-based machine.
What you’ll build
Qwen3-TTS voice cloning takes text and a reference recording, then synthesizes the text in the reference speaker’s voice at 24 kHz.
The server workflow uses Python and ONNX Runtime to run a cascade of ONNX models. The provided application and runner are specific to this Qwen3-TTS package.
For the server workflow, you’ll:
  1. Connect to an Arm Neoverse-based Linux machine. The workflow was validated with an AWS Graviton4-based instance running Ubuntu.
  2. Create a Python virtual environment for ONNX Runtime.
  3. Download the supported ONNX model package from Hugging Face.
  4. Start the web application and connect to it through an SSH tunnel.
  5. Record or upload reference audio, generate speech, and play or download the result in your browser.
  6. Optionally run the same model from the terminal with the supplied onnx_tts_runner.py script.
Warning
Clone a voice only when you have the speaker’s permission. Don’t use generated speech to impersonate or mislead others.
Confirm the machine architecture
The server package contains a cascade of ONNX models optimized for AWS Graviton4-based instances. You can also use other Arm Neoverse-based Linux machines running locally or through a cloud provider.
The following cloud instance types provide a suitable starting configuration with four vCPUs and 32 GB of memory:
Cloud providerSuggested instanceArm processorvCPUsMemory
AWSr8g.xlarge AWS Graviton4432 GiB
Google Cloudc4a-highmem-4 Google Axion432 GB
Microsoft AzureStandard_E4ps_v6 Azure Cobalt 100432 GiB
Instance availability varies by region. Select a larger memory configuration for larger models or longer context lengths.
Use an arm64 image of Ubuntu 24.04 LTS for the recommended environment. Other Arm Neoverse Linux distributions can work, but their package installation commands might differ.
On your Neoverse-based machine, confirm that the operating system reports the aarch64 architecture:
uname -m
The expected output is:
        aarch64
Create the Python environment
Install the required system packages:
sudo apt update
sudo apt install -y \
  python3 \
  python3-venv \
  python3-pip \
  libsndfile1 \
  libgomp1 \
  ffmpeg \
  wget
Create the working directory and Python virtual environment:
mkdir -p ~/qwen3-tts
cd ~/qwen3-tts
python3 -m venv .venv
source .venv/bin/activate
python -m pip install --upgrade pip
Install the Qwen3-TTS server dependencies:
python -m pip install \
  "onnxruntime==1.26.0" \
  "transformers==4.57.3" \
  numpy \
  soundfile \
  librosa \
  torch \
  "huggingface_hub[cli]" \
  fastapi \
  uvicorn \
  python-multipart
Download the web application and runner
Download the browser application and ONNX Runtime runner:
BASE_URL=https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/servers-and-cloud-computing/ai-portal-text-to-speech
for FILE in onnx_tts_runner.py tts_web.py; do
  if ! wget -nv "$BASE_URL/files/$FILE" -O "$FILE.tmp"; then
    rm -f "$FILE.tmp"
    echo "Failed to download $FILE" >&2
    break
  fi
  mv "$FILE.tmp" "$FILE"
done
Confirm that the files are present and have sizes greater than zero bytes:
  if [ -s "$FILE" ]; then
    echo "Present: $FILE"
  else
    echo "Missing or zero size: $FILE"
  fi
done
Download the server model
Open the Qwen3-TTS ONNX package in the Arm AI Portal and inspect the model card. Select Use this Model, then Open on Hugging Face to reach the Arm/qwen3-tts-0-6b-int8-onnx-graviton-g4 repository.
Set QWEN_MODEL_ID to the complete repository ID and download the model:
QWEN_MODEL_ID=Arm/qwen3-tts-0-6b-int8-onnx-graviton-g4
hf download "$QWEN_MODEL_ID" --local-dir .
Confirm that the ONNX models and text-path artifacts are present and have sizes greater than zero bytes:
for FILE in \
  onnx_cascade_driver.py \
  sample_input.wav \
  text_path_config.json \
  text_path_weights.npz; do
  else
  fi
done
find . -maxdepth 1 -type f -name "*.onnx" -size +0c | wc -l
You should expect 10 *.onnx files.
The output is similar to:
        Present: onnx_cascade_driver.py
Present: sample_input.wav
Present: text_path_config.json
Present: text_path_weights.npz
10
You’ve prepared an Arm Neoverse-based machine and downloaded the Qwen3-TTS ONNX package, browser application, and terminal runner.
Next, you’ll start the web application and generate speech without manually copying audio files between your computer and the cloud instance.
