Explore related resources
Give feedback
AI-assisted
Close
Do I need to install the Arm AI Portal MCP server locally?
No. The server uses Streamable HTTP. Add it to your AI harness by specifying the MCP server’s URL.
How do I know the MCP server is connected to my AI harness?
List the configured MCP servers and confirm that arm-ai appears as connected. Then, ask your harness to use the Arm AI Portal MCP server and call find_model. If it uses web search instead, explicitly ask it to use the arm-ai MCP tools.
What kind of query helps me narrow to the right model?
Start with your goal, then add constraints such as model task, Arm target, runtime, latency, memory, and performance. If you’re unsure of the task, begin with a broad question and refine based on the returned options.
How do I use the MCP server to plan a deployment?
Prompt your harness the model and target that you selected and how you can access the target. Ask it to separate prerequisites, target preparation, deployment, validation, and cleanup. Review the plan and approve it before the harness runs commands or changes the target.
How do I validate a deployment guided by the MCP server?
Ask your harness to check the deployment status and run a representative inference test. Use input and success criteria that match the model task. A running process or successful network response doesn’t prove that the model produces a correct result.
