Give feedback
AI-assisted
Close
Which script should I run to generate text in the terminal or browser?
Use run_model.py for terminal generation and genai_web.py for an optional local browser interface. Both entry points call the shared adapter, which uses the supplied ONNX Runtime GenAI implementation.
How do I choose and set the correct ID for a model from the Arm AI Portal?
Select your model in the Arm AI Portal and copy its Hugging Face repository ID in the form Arm/<model-repository-name>. When you use the supplied adapter, choose an ID from the confirmed models table. If you generated an adapter for another runtime, keep your existing MODEL_ID and follow that package’s model-type and prompt guidance.
How do I verify my adapter before I run a model?
Use validate_adapter.py to check the adapter contract and required package files. If the check fails, align your implementation with the interface defined in adapter_contract.py.
What do I see after a successful terminal run?
You’ll see generated text in the terminal. run_model.py reports time to first token and decode throughput.
Which components change if I switch to another runtime or model format?
Implement the adapter defined in adapter_contract.py for the target package, replacing the supplied ONNX Runtime GenAI implementation in model_adapter.py. You can retain the terminal and web runners and follow the alternative package’s guidance for model type and prompting.
