How the shared application works
The shared application includes the following runner scripts:
How the application resolves the model directory
adapter_contract.py maps each Hugging Face repository ID to a predictable local directory. Replacing / with __ keeps the organization and repository name while producing one directory name:
def model_directory(model_id: str) -> Path:
    return Path("models") / model_id.replace("/", "__")
The download_model.py, run_model.py, genai_web.py, and validate_adapter.py scripts use this same mapping. The downloader retrieves the complete repository, and the ONNX adapter decides which files it needs.
How the adapter contract is defined
adapter_contract.py defines the operations used by the terminal and browser applications:
class TextGenerationAdapter(ABC):
    @property
    @abstractmethod
    def interaction_mode(self) -> str:
    @abstractmethod
    def validate_model_directory(self) -> None:
    @abstractmethod
    def load(self) -> None:
    @abstractmethod
    def stream(
        self,
        prompt: str,
        max_new_tokens: int,
        enable_thinking: bool,
    ) -> Iterator[GenerationChunk]:
The adapter reports chat or completion to the surrounding application. Runtime-specific prompt names and model objects remain inside the adapter.
How the adapter validates an ONNX Runtime GenAI package
model_adapter.py checks for the files needed by ONNX Runtime GenAI:
required_files = [
    "genai_config.json",
    "model.onnx",
    "tokenizer.json",
    "tokenizer_config.json",
model.onnx contains the model graph. Some models also use an external model.onnx.data weights file referenced by the graph. genai_config.json describes how ONNX Runtime GenAI should load and generate with the model.
validate_adapter.py constructs the active adapter and calls validate_model_directory(). This keeps package validation beside the runtime implementation rather than hard-coding ONNX filenames in the downloader.
How the adapter detects base and instruction-tuned models
model_adapter.py detects three prompt-format cases:
if (self.model_dir / "chat_template.jinja").is_file():
    return "chat", model_type
if (
    model_type == "qwen2"
    and self._token_text(tokenizer_config.get("eos_token")) == "<|im_end|>"
    return "qwen25", model_type
return "raw", model_type
The cases are as follows:
  • chat uses the chat_template.jinja included with an instruction-tuned model.
  • qwen25 supplies the equivalent Qwen2.5 ChatML template because that model bundle doesn’t include a separate template file.
  • raw sends unfinished text to a base model without wrapping it as a conversation.
This logic belongs in the adapter because base and instruction-tuned models require different tokenizer files and prompt handling. The terminal and browser applications only need to know whether they should present chat or text completion.
How the adapter loads ONNX Runtime GenAI
model_adapter.py imports ONNX Runtime GenAI and Transformers inside load(), after the model package has been validated.
The adapter creates a fast tokenizer from the downloaded tokenizer.json and reads the model’s special tokens from tokenizer_config.json. It then configures the ONNX Runtime CPU provider and thread count:
config = og.Config(str(self.model_dir))
config.clear_providers()
config.append_provider("CPU")
config.overlay(json.dumps({
    "model": {
        "decoder": {
            "session_options": {
                "intra_op_num_threads": self.threads,
Transformers performs tokenization and chat-template rendering only. ONNX Runtime GenAI loads the model and performs inference.
How ONNX Runtime uses KleidiAI kernels
KleidiAI is an open-source library of optimized microkernels for AI workloads on Arm CPUs. A microkernel implements a performance-critical part of an operator, such as quantized matrix multiplication, using Arm CPU features including DotProd, I8MM, SVE, and SME.
KleidiAI doesn’t load the model or manage token generation. ONNX Runtime provides those functions and can use KleidiAI inside its CPU execution path for supported operators. The adapter doesn’t need a separate KleidiAI API call. Selecting the CPU provider allows ONNX Runtime to choose an applicable kernel from the installed runtime.
Note
KleidiAI dispatch depends on the installed runtime build and model operators. The dispatch also depends on tensor shapes, quantization format, and CPU features. Don’t assume that every model or Arm machine selects the same kernels.
How the adapter formats the prompt
model_adapter.py encodes base-model prompts directly. For instruction-tuned models, it applies the selected chat template:
if self.prompt_style == "raw":
    return list(self.tokenizer.encode(prompt, add_special_tokens=True))
token_ids = self.tokenizer.apply_chat_template(
    [{"role": "user", "content": prompt}],
    tokenize=True,
    add_generation_prompt=True,
    **template_options,
add_generation_prompt=True adds the model-specific marker that indicates the assistant should begin responding. For Qwen3, the adapter also passes the enable_thinking option into its template.
How the adapter streams generated text
model_adapter.py generates one token at a time and yields a GenerationChunk containing decoded text and its token count:
yield GenerationChunk(
    text=token_stream.decode(token_id),
    token_count=1,
A new decoder stream is created for every generation request. This prevents decoding state from one terminal or web request from carrying into the next request.
How the terminal and browser applications interact with the adapter
run_model.py and genai_web.py construct and load the same adapter:
adapter = ModelAdapter(model_dir, args.prompt_style, args.threads)
adapter.validate_model_directory()
adapter.load()
Both applications consume the same stream:
for chunk in adapter.stream(
    prompt,
    max_new_tokens,
    enable_thinking,
    generated_tokens += chunk.token_count
run_model.py writes each text fragment to the terminal. genai_web.py sends the fragments as newline-delimited JSON events. Both measure time to first token and decode throughput without importing ONNX Runtime GenAI directly.
You’ve seen how the terminal and browser applications call the supplied adapter contract. The adapter validates an ONNX Runtime GenAI package and handles base and instruction-tuned prompts. It configures CPU inference, allows supported operations to use KleidiAI, and streams decoded tokens.
You can extend the supplied adapter to your own use case.
Next, if the supplied adapter doesn’t meet your needs, you can learn about other cloud large language model (LLM) deployment options.
