Deploy an AI agent on Arm with llama.cpp and KleidiAI
Introduction to AI Agents and Agent Use Cases
Set Up Your Local Environment to Run an AI Application
AI Agent Application
Explore and Test Your AI Agent
The steps are designed for Arm servers running Ubuntu 22.04 LTS. They were tested on an Amazon EC2
m7g.xlarge instance powered by Graviton3, and expect at least four cores, 16 GB of memory, and 32 GB of disk.Build
llama.cpp and download the quantized Llama 3.1 8B model. Ensure the Python dependencies, including llama-cpp-agent and llama-cpp-python, are installed in the active environment.Place the downloaded model at the path referenced by
model_path in agent.py. Keep the directory structure consistent with the code so the model loads without modification.Check the script’s output for a selected tool/function name and its arguments, followed by the function’s return data. If the agent replies directly, you will see a model-generated response without a function invocation.
Functions are declared in
agent.py and registered through llama-cpp-agent. The LLM analyzes the input and selects among the predefined functions based on intent and context.
