Give feedback
AI-assisted
Close
How do I know my environment is ready to use SVE intrinsics?
Use an Arm Neoverse server with SVE support that matches the prerequisites. If in doubt, choose an instance class listed in the Learning Path, such as one based on AWS Graviton3 or later, and run the scalar baseline before writing SVE code.
What should I record for the baseline before starting vectorization?
Capture the scalar Adler-32 checksum for a known input and record the timing you will compare against later. Keep the input size and conditions consistent so results are reproducible when you switch to the SVE version.
When applying the `NMAX` optimization, where should the modulo be performed?
Defer the modulo operation and apply it after processing a block instead of on every byte. This reduces division work and removes the dependency that blocks vectorization of the inner loop.
Which parts of the Adler-32 loop should be vectorized first?
Vectorize the a accumulator first because it maps cleanly to vector loads and a reduction with svaddv. Then handle the b accumulator using a weighted approach and svdot, as each element contributes differently within a block.
How should I handle data lengths that are not a multiple of the SVE vector length?
Use a vector-length-agnostic loop with predication. Generate a predicate with svwhilelt and apply it to loads and arithmetic so tails are processed correctly on any SVE width.
