Why modulo operations block vectorization
Look at the original scalar loop again:
for (size_t i = 0; i < len; i++) {
    a = (a + data[i]) % MOD_ADLER;
    b = (b + a) % MOD_ADLER;
The % MOD_ADLER operation runs on every single byte. Division is expensive, and doing it 10 million times for a 10 MB buffer is a significant cost. More importantly, it prevents vectorization because each iteration depends on the modulo-reduced result of the previous one.
The standard solution is to defer the modulo. You can ask your AI assistant how to optimize Adler-32.
Ask AI about the cost of modulo operations
Ask your assistant the following question. Your prompt can be similar to:
Are there any common techniques to optimize adler-32 and reduce modulo operations?
A sample output is:
        The deferred modulo trick
  Instead of % 65521 every byte, you accumulate freely for a batch of bytes, then apply the modulo once at the end of the batch.
  This replaces N expensive divisions with N cheap additions + 1 division.
  How many bytes before overflow?
  We need to find the maximum batch size n where neither a nor b can overflow a uint32_t (max value 2³² - 1 = 4,294,967,295).
  For `a`: worst case is every byte = 255, and a starts at its max post-modulo value (65520):
  a_max = 65520 + 255 * n
  For `b`: b accumulates the running sum of a values. Worst case, b starts at 65520 and each a value is as large as possible:
  b_max = 65520 + Σ(65520 + 255*k) for k=1..n
        = 65520 + 65520*n + 255*n*(n+1)/2
  b overflows first because it grows quadratically. Solving for b_max ≤ 2³² - 1:
  65520 + 65520*n + 255*n*(n+1)/2 ≤ 4,294,967,295
  This gives n = 5552.
  The standard block size
  5552 bytes is the universally used batch size in optimized Adler-32 implementations (zlib, chromium, etc.). The loop structure
  becomes:
  uint32_t a = 1, b = 0;
  while (len > 0) {
      size_t block = (len < 5552) ? len : 5552;
      len -= block;
      // Fast inner loop — no modulo here
      for (size_t i = 0; i < block; i++) {
          a += *data++;
          b += a;
      // Modulo once per block
      a %= MOD_ADLER;
      b %= MOD_ADLER;
  The payoff
  │ Approach                    │ Modulo operations for 64KB input │
  │ Per-byte modulo             │ 65,536 × 2 = **131,072**         │
  │ Deferred (5552-byte blocks) │ 12 × 2 = **24**                  │
  That's a ~5,400x reduction in modulo operations. And the inner loop is now just additions — which is exactly what SVE svdot and
  svadd can vectorize.
The response explains the NMAX technique. The key insight is that you can accumulate many bytes before the intermediate values overflow a 32-bit integer, as long as you apply the modulo periodically.
Implement the scalar NMAX version
Before adding SVE, implement the NMAX optimization using scalar values. This is a useful intermediate step: it lets you verify the optimization is correct and measure its impact independently of vectorization.
Create adler32-nmax.c:
 *  Adler-32 with NMAX modulo deferral — scalar optimization
#include <stdint.h>
#include <stddef.h>
#define MOD_ADLER 65521
#define NMAX      5552   /* max bytes before b overflows uint32_t */
uint32_t adler32(const uint8_t *data, size_t len)
    uint32_t a = 1;
    uint32_t b = 0;
    while (len > 0) {
        size_t n = len < NMAX ? len : NMAX;
        len -= n;
        /* inner loop: no modulo */
        for (size_t i = 0; i < n; i++) {
            a += data[i];
            b += a;
        data += n;
        a %= MOD_ADLER;
        b %= MOD_ADLER;
    return (b << 16) | a;
The structure is now an outer loop that processes NMAX-byte blocks, and an inner loop with no modulo at all. The modulo runs only once per 5552 bytes instead of once per byte.
Update the Makefile to test the NMAX version
Update your Makefile to make it easy to switch from adler32-simple.c to adler32-nmax.c
CC      = gcc
CFLAGS  = -O3 -mcpu=native -flto -Wall -Wextra
LDFLAGS = -flto
TARGET  = adler32-test
# Change this line to switch implementations:
# IMPL    = adler32-simple.c
IMPL  = adler32-nmax.c
$(TARGET): $(IMPL) adler32-test.c
	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $(IMPL) adler32-test.c
run: $(TARGET)
	./$(TARGET)
clean:
	rm -f $(TARGET)
.PHONY: run clean
Build and run with the NMAX version:
make clean && make run
The output is similar to:
        Correctness: adler32("Wikipedia") = 0x11E60398 [PASS]
Performance:
  1 KB          1024 bytes  100000 iters    49.180 ms    1985.7 MB/s  checksum=0x37B4063C
  10 KB        10240 bytes   10000 iters    48.925 ms    1996.0 MB/s  checksum=0x5FA40D73
  100 KB      102400 bytes    1000 iters    48.893 ms    1997.4 MB/s  checksum=0x2378D74C
  1 MB       1048576 bytes     100 iters    50.012 ms    1999.5 MB/s  checksum=0x058B4B08
  10 MB     10485760 bytes      10 iters    50.097 ms    1996.1 MB/s  checksum=0x285FF1B1
This is a substantial improvement over the original scalar version, achieved by removing the per-byte modulo. Make a note of these numbers as your intermediate baseline.
You now have a clean inner loop with no modulo, which is the right structure for SVE vectorization. You learned why deferring the modulo is safe and how to calculate the NMAX bound. You then implemented the scalar NMAX optimization and measured a significant speedup.
The inner loop of the NMAX version is now a simple accumulation loop. Next, you’ll vectorize it with SVE intrinsics.
