Optimize Adler-32 with SVE and the Arm MCP server
Understand the Adler-32 algorithm and optimization approach
Set up the project and establish a baseline
Understand core SVE concepts for vectorization
Defer the modulo with the NMAX optimization
Vectorize the Adler-32 inner loop with SVE intrinsics
Benchmark and analyze the results
SVE concepts you need before writing code
SVE is different from fixed-width SIMD such as Neon. The vector length is not fixed at compile time and is determined at runtime by the hardware. This means you can’t write for (i = 0; i < n; i += 16) and assume you’re processing 16 bytes per iteration. SVE code must be Vector Length Agnostic (VLA) to work correctly on any processor with SVE support.
Before writing SVE intrinsics, it’s helpful to understand three things:
- How SVE predicates control which elements are active
- How to handle loop tails when data length isn’t a multiple of the vector length
- How to widen narrow data types for accumulation
Use the Arm MCP server with your AI assistant to ask the following questions and read the responses. By doing this, you can understand the concepts well enough to recognize when you need each one, without needing to memorize intrinsic names.
Comparing SVE and Neon
Start with understanding the big picture about SVE.
Ask AI about SVE versus Neon
Ask your assistant the following question. Your prompt can be similar to:
Ask the Arm MCP server what is SVE and how does it differ from Neon? My Makefile targets the native CPU on a Neoverse processor.
A sample response is:
Here's what the Arm knowledge base says:
SVE vs Neon
Neon (also called ASIMD/Advanced SIMD) is Arm's original SIMD extension. It uses fixed 128-bit vector registers (Q0–Q31). Every
Neon instruction operates on exactly 128 bits — if your data doesn't fit neatly into 128-bit chunks, you write explicit scalar
cleanup code for the remainder.
SVE (Scalable Vector Extension) is fundamentally different in that it uses a Vector Length Agnostic (VLA) programming model. Key
differences:
│ │ Neon │ SVE / SVE2 │
│ Vector width │ Fixed 128-bit │ Scalable: 128 to 2048 bits (in 128-bit increments) │
│ Registers │ 32 × 128-bit V regs │ 32 × scalable Z regs + 16 predicate regs │
│ Tail handling │ Manual scalar cleanup │ Built-in **per-lane predication** (`svwhilelt`, predicate masks) │
│ Loop model │ Fixed iteration count │ VLA: `svcntb()` at runtime, one binary works on any SVE width │
│ Gather/scatter │ No │ Yes — `svld1_gather`, `svst1_scatter` │
│ Dot product │ Limited (Armv8.2 UDOT) │ Full `svdot` family with widening accumulate │
The key innovation is predication: every SVE instruction can be masked by a predicate register, so the last iteration of a loop
naturally handles any remainder without scalar cleanup. Your adler32-sve.c uses this pattern directly — svwhilelt_b8 generates the
predicate, and all the svdot/svld1 calls respect it.
What this means for your Neoverse-V2
Your system has SVE2 with 128-bit vectors (Neoverse-V2 implements 128-bit SVE). That's the same width as Neon, but you still
benefit from:
- Predicated loads/stores — no cleanup loops needed
- Richer instruction set — svdot, svindex, gather/scatter, bitperm, crypto extensions
- SVE2 extras — sve2-aes, sve2-bitperm, sve2-sha3 (all present on your CPU)
- Portability — the same SVE binary runs unmodified on Graviton4 (Neoverse-V2, 128-bit) or future chips with wider vectors
Since -mcpu=native on your system resolves to armv9-a+sve2-*, your Makefile is already generating SVE2 code. Your adler32-sve.c
uses svdot_u32 and svdot_n_u32 which are SVE dot-product intrinsics — these are well-suited to the Neoverse-V2.
For deeper dives, Arm has several relevant learning paths:
- Port Code to Arm SVE (https://learn.arm.com/learning-paths/servers-and-cloud-computing/sve/)
- Learn SVE and SME programming with SIMD Loops (https://learn.arm.com/learning-paths/cross-platform/simd-loops/)
- Accelerate Bitmap Scanning with Neon and SVE
(https://learn.arm.com/learning-paths/servers-and-cloud-computing/bitmap_scan_sve2/)
The response explains that Neon uses fixed 128-bit vectors, while SVE uses vectors of variable length (a multiple of 128 bits, from 128 to 2048 bits). Neoverse N2 and Neoverse V2 support SVE with 128-bit vectors. Neoverse V1 supports SVE with 256 bit vectors. The key point is that your code doesn’t need to know the vector length at compile time. SVE intrinsics handle it at runtime.
Predicates and loop tails
In fixed-width SIMD such as Neon, every lane in a vector always participates in every operation. This works fine when your data length is a multiple of the vector width. However, it forces you to write special-case scalar code to handle the leftover elements at the end of a loop. With SVE’s variable vector length, you don’t know the vector width at compile time, so that approach breaks down entirely.
SVE solves this with predicate registers. A predicate is a bitmask with one bit per vector element. Each bit controls whether the corresponding lane is active or inactive for a given operation. Inactive lanes are ignored: they don’t load memory, don’t compute, and don’t write results. This lets you run the same vector code on the final partial chunk of data as on every full chunk before it. You don’t need a special-case tail loop.
Ask AI how predicate registers work
Masking with predicate registers seems like a key concept in SVE. How does it work to handle loops when my data length isn't a multiple of the vector length?
SVE predication for loop tails
SVE has 16 predicate registers (P0–P15) with one bit per byte lane. Each bit says "active" or "inactive." Nearly every SVE
instruction takes a predicate, so inactive lanes are simply skipped — loads don't fault, stores don't write, arithmetic ignores
them.
The canonical SVE loop
uint64_t vl = svcntb(); // vector length in bytes (runtime)
for (uint64_t i = 0; i < n; i += vl) {
svbool_t pg = svwhilelt_b8(i, n); // ① generate mask
svuint8_t v = svld1_u8(pg, &data[i]); // ② predicated load
// ... compute with v ... // ③ all ops respect pg
① `svwhilelt_b8(i, n)` — compares each lane index i, i+1, i+2, ... against n. Returns a predicate with true for every index < n,
false otherwise.
With vl=16 and n=50:
i= 0: pg = [1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1] ← full vector
i=16: pg = [1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1] ← full vector
i=32: pg = [1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1] ← full vector
i=48: pg = [1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0] ← only 2 remaining
② Predicated load — svld1_u8(pg, ptr) loads only active lanes. Inactive lanes become zero. It won't fault even if the inactive
addresses are unmapped — this is a hardware guarantee.
③ Downstream arithmetic — operations like svdot, svadd, etc. either take the predicate directly or naturally get zeros from the
inactive lanes of the load. No contribution from out-of-bounds data.
Compare with Neon (fixed 128-bit)
// Neon: need two separate loops
for (i = 0; i + 16 <= n; i += 16) {
uint8x16_t v = vld1q_u8(&data[i]); // must have 16 valid bytes
// ... compute ...
for (; i < n; i++) { // scalar cleanup for remainder
// ... handle tail byte-by-byte ...
With SVE, the same loop body handles both full and partial iterations. No cleanup loop.
The three predication modes
SVE intrinsics use a suffix to control what happens to inactive lanes:
│ Suffix │ Inactive lanes │ When to use │
│ `_z` │ Zeroed │ Need a clean zero for inactive elements │
│ `_m` │ Merged (keep old value) │ Conditional updates within a vector │
│ `_x` │ Don't care (undefined) │ Fastest — when inactive lanes are never read │
Key takeaway
The predicate register turns the loop tail from a code structure problem (separate cleanup path) into a data problem (a mask). One
loop, one code path, any data length, any vector width.
The response explains that the svwhilelt_b8(i, n) intrinsic creates a predicate where element k is active if i + k < n. This handles the loop tail automatically. When you’re near the end of the data, the predicate deactivates the elements that would go out of bounds.
An SVE loop usually looks like this:
uint64_t vl = svcntb(); // vector length in bytes, determined at runtime
for (size_t i = 0; i < n; i += vl) {
svbool_t pg = svwhilelt_b8(i, n); // predicate: active lanes where i+k < n
svuint8_t data = svld1_u8(pg, &buf[i]);
// ... process data ...
The loop body runs even for the final partial vector. The predicate ensures only valid bytes are processed.
Loading bytes and widening to 32 bit
For Adler-32, you’re loading uint8_t bytes but accumulating into uint32_t sums.
Ask AI about widening
The adler32 loop accumulates uint8_t values into a uint32_t sum. How does SVE handle widening from 8 bit to 32 bit elements?
A sample output is:
Loading uint8_t values
svbool_t pg = svwhilelt_b8(i, len);
svuint8_t bytes = svld1_u8(pg, &data[i]); // predicated load of uint8_t elements
Widening from 8-bit to 32-bit
SVE widens one step at a time (8→16→32), and you select the bottom or top half of the source vector at each step:
// Step 1: 8-bit → 16-bit (unpack lower and upper halves)
svuint16_t lo16 = svunpklo_u16(bytes); // lower half of bytes, zero-extended to u16
svuint16_t hi16 = svunpkhi_u16(bytes); // upper half of bytes, zero-extended to u16
// Step 2: 16-bit → 32-bit (unpack again)
svuint32_t ll32 = svunpklo_u32(lo16); // lower quarter → u32
svuint32_t lh32 = svunpkhi_u32(lo16); // second quarter → u32
svuint32_t hl32 = svunpklo_u32(hi16); // third quarter → u32
svuint32_t hh32 = svunpkhi_u32(hi16); // upper quarter → u32
Visually, for a 128-bit vector (16 bytes):
bytes (16 x u8): [b0 b1 b2 b3 | b4 b5 b6 b7 | b8 b9 b10 b11 | b12 b13 b14 b15]
svunpklo_u16 svunpkhi_u16
lo16 (8 x u16): [b0 b1 b2 b3 | b4 b5 b6 b7 ]
hi16 (8 x u16): [b8 b9 b10 b11| b12 b13 b14 b15]
ll32 (4 x u32): [b0 b1 b2 b3 ]
lh32 (4 x u32): [b4 b5 b6 b7 ]
hl32 (4 x u32): [b8 b9 b10 b11]
hh32 (4 x u32): [b12 b13 b14 b15]
Accumulating into a uint32_t sum vector
Once widened, you add each quarter into your running svuint32_t accumulator:
svbool_t pg32 = svptrue_b32();
sum_a = svadd_u32_x(pg32, sum_a, ll32);
sum_a = svadd_u32_x(pg32, sum_a, lh32);
sum_a = svadd_u32_x(pg32, sum_a, hl32);
sum_a = svadd_u32_x(pg32, sum_a, hh32);
Alternative: `svld1ub_u32` — direct widening load
If you'd rather avoid the unpack chain, SVE can load bytes directly into 32-bit lanes:
svbool_t pg32 = svwhilelt_b32(i, len);
svuint32_t vals = svld1ub_u32(pg32, &data[i]); // loads u8, zero-extends to u32
sum_a = svadd_u32_x(pg32, sum_a, vals);
The tradeoff: this processes only VL/4 bytes per iteration (4 bytes on your 128-bit Neoverse-V2) instead of VL bytes (16). Simpler
code, but fewer elements per loop iteration.
Which approach for Adler-32?
The unpack chain is better for performance — you process a full vector of bytes each iteration. The svld1ub_u32 approach is
simpler but does 4x more loop iterations on your hardware.
For the b accumulator in Adler-32, you'll also need a prefix sum pattern since b += a after each byte addition — that's the
trickiest part.
The response introduces svld1_u8 for loading bytes, and explains that SVE doesn’t have a single “load and widen” intrinsic. Instead, you use svld1ub_u32 to load bytes and extend them with zeroes directly into a 32-bit vector. This is the right approach for Adler-32 because your accumulators are 32 bit.
The Arm MCP server will return the exact signature:
svuint32_t svld1ub_u32(svbool_t pg, const uint8_t *base);
This loads one byte per active 32-bit lane and extends each byte with zeroes to 32 bits. On a processor with 256 bit SVE vectors, this loads 8 bytes per iteration (8 lanes × 32 bits = 256 bits).
The dot product intrinsic
If the AI assistant response includes something you don’t understand, you can continue to ask for more explanation. For example, one of the previous responses implies svdot is commonly used for arithmetic. You can ask for more information about what it does.
Ask AI about the svdot instruction
Ask your assistant the following questions. Your prompt can be similar to:
What is the svdot intrinsic? How does it differ from a simple multiply and accumulate operation?
A sample output is:
`svdot` — Dot Product Intrinsic
From the Arm intrinsics reference (https://developer.arm.com/architectures/instruction-sets/intrinsics/#q=svdot[_u32]):
svuint32_t svdot_u32(svuint32_t acc, svuint8_t op1, svuint8_t op2);
For each u32 element i in the result:
acc[i] += (u32)op1[4i+0] * (u32)op2[4i+0]
+ (u32)op1[4i+1] * (u32)op2[4i+1]
+ (u32)op1[4i+2] * (u32)op2[4i+2]
+ (u32)op1[4i+3] * (u32)op2[4i+3]
It does three things in one instruction: widens u8→u32, multiplies, and accumulates groups of 4.
How it differs from a simple multiply-accumulate
A naive approach would be:
Step 1: widen 16 × u8 → 16 × u32 (svunpklo/hi, twice)
Step 2: multiply 16 × u32 * 16 × u32 (svmul)
Step 3: accumulate into u32 vector (svadd)
That's 5+ instructions and needs 4× the register space (16 u8 elements expand to 16 u32 elements across multiple vectors).
svdot instead:
One instruction: 16 × u8 → 4 × u32 (widened, multiplied, summed, accumulated)
The key differences:
│ │ Multiply-accumulate │ svdot │
│ Instructions │ 5+ (unpack, mul, add) │ 1 │
│ Output elements │ Same count as input │ **4× fewer** (groups of 4 reduced) │
│ Register pressure │ 4× wider intermediate vectors │ Stays in u32 width │
│ Widening │ Explicit, multi-step │ Implicit, fused │
The 4:1 reduction is the critical property. On your 128-bit Neoverse-V2, a vector holds 16 u8 bytes. After svdot, you have 4 u32
lanes — each holding the accumulated sum of 4 bytes. This compression means you process 4× more input data per u32 accumulator
lane than you could with element-wise operations.
There's also a scalar-broadcast variant:
svuint32_t svdot_n_u32(svuint32_t acc, svuint8_t op1, uint8_t op2);
This multiplies every byte by the same scalar value op2. With op2 = 1, it becomes a pure widening sum — no multiplication cost,
just acc[i] += bytes[4i+0] + bytes[4i+1] + bytes[4i+2] + bytes[4i+3].
The response explains that svdot computes a dot product between two vectors of narrow elements and accumulates the result into a vector of wider elements. For example, svdot_u32 takes two svuint8_t vectors and a svuint32_t accumulator, multiplying corresponding 8-bit elements and adding the products into 32-bit lanes.
The signature is:
svuint32_t svdot_u32(svuint32_t op1, svuint8_t op2, svuint8_t op3);
You’ll use this to compute the weighted sum for the B accumulator. The reason will become clear in the SVE implementation section.
You’ve now learned how SVE predicates handle loop tails without special-case code. You’ve investigated intrinsics for loading bytes and dot product and learned how to ask for more details. You’ve also understood that SVE code must be Vector Length Agnostic.
Next, you’ll restructure the Adler-32 algorithm to remove the modulo operation on each byte. This is necessary to use these intrinsics effectively.
