Explore related resources
Give feedback
AI-assisted
Close
Do I need native driver support for VK_ARM_data_graph and VK_ARM_tensors to run the samples?
No. The ML Emulation Layers for Vulkan simulate these extensions so you can build and run the samples during development.
How do I run the Simple Tensor and Data Graph sample after building it?
Run build\windows\app\bin\Release\AMD64\vulkan_samples.exe sample simple_tensor_and_data_graph from the Vulkan-Samples repository. A new window opens and visualizes the operation.
How do I run a 2D average pooling operation?
Run the Simple Tensor and Data Graph sample to execute a 2D average pooling operation through a data graph pipeline. Create input and output tensors, bind them with descriptor sets and pipeline layouts, and dispatch the SPIR-V-defined network.
What does the NSS Scenario Runner download include?
The NSS model release includes a Windows-compatible Scenario Runner binary, the VGF model, and one input frame with expected output data. You can use these assets to run an end-to-end workflow and examine the VGF model.
How do I capture a Vulkan Samples frame in RenderDoc?
Use RenderDoc when you need to diagnose unexpected visual output, examine Vulkan API calls, inspect resource states, or validate data graph pipeline execution. In Launch Application, set the Executable Path, Working Directory, and Command-line Arguments, select Launch, then press the F12 key while the sample is active. In the capture, inspect Vulkan API calls, shader inputs and outputs, and resource states.
Return to Mobile, Graphics, and Gaming
