Train a HuBERT model for voice sentiment classification
In this section, you will train a model to classify voice sentiment directly from audio. The raw waveform is converted into audio-based features, then passed through a pre-trained HuBERT model with a classification head.
For this Learning Path, you train the model on the RAVDESS dataset using three sentiment classes: neutral, happy, and angry. This keeps the demo manageable while still showing a realistic transfer-learning workflow. You can extend the same approach to more sentiment classes or other datasets.
Before you begin, make sure you have completed the environment setup from the previous section and installed the required Python dependencies.
This example uses a simple per-sample training loop for clarity. On CPU, training can take 10 to 30 minutes or more depending on your machine. Apple Silicon mps and CUDA-enabled GPUs are often faster.
All code snippets in Steps 2.1 to 2.5 are meant to be added to a single Python file: train_sentiment_model.py in your project root ($HOME/voice-sentiment-assistant).
Make sure you’re located in the project directory:
cd $HOME/voice-sentiment-assistant
Step 2.1 - Prepare the dataset
This step downloads the RAVDESS speech dataset, extracts it locally, and builds a dataframe that maps each audio file to a sentiment label. RAVDESS encodes emotion labels in the filename format, which you use to select the classes for this demo.
In practice, this turns a folder of audio files into a structured table that your training code can work with. Each row is one example, and each column stores details such as the file path, actor ID, and sentiment label.
Add this to a new file called train_sentiment_model.py:
import os
import urllib.request
import zipfile
import pandas as pd
# Download and unpack the dataset into the local project directory.
RAVDESS_URL = "https://zenodo.org/records/1188976/files/Audio_Speech_Actors_01-24.zip?download=1"
OUTPUT_DIR = "data/ravdess"
ZIP_PATH = f"{OUTPUT_DIR}/Audio_Speech_Actors_01-24.zip"
EXTRACT_DIR = f"{OUTPUT_DIR}/Audio_Speech_Actors_01-24"
os.makedirs(OUTPUT_DIR, exist_ok=True)
if not os.path.exists(ZIP_PATH):
    print("Downloading dataset...")
    urllib.request.urlretrieve(RAVDESS_URL, ZIP_PATH)
if not os.path.exists(EXTRACT_DIR):
    zipfile.ZipFile(ZIP_PATH).extractall(EXTRACT_DIR)
emotion_map = {1: "neutral", 3: "happy", 5: "angry"}
data = []
for actor in os.listdir(EXTRACT_DIR):
    actor_path = os.path.join(EXTRACT_DIR, actor)
    if not os.path.isdir(actor_path):
        continue
    for f in os.listdir(actor_path):
        if f.endswith(".wav"):
            # RAVDESS encodes emotion ID in the filename.
            emotion = int(f.split("-")[2])
            if emotion in emotion_map:
                data.append({
                    "emotion": emotion_map[emotion],
                    "actor": actor,
                    # Store absolute sample path for later loading.
                    "path": os.path.join(actor_path, f)
df = pd.DataFrame(data)
print(df.head())
print(df["emotion"].value_counts())
At the end of this step, you should have a dataframe with the selected audio samples and their sentiment labels.
Step 2.2 - Create train and validation splits
Next, split the dataset by speaker so the same speaker does not appear in both training and validation sets. This helps avoid data leakage and gives you a more realistic evaluation. This matters because a speech model can accidentally learn speaker-specific traits instead of sentiment if the same speakers appear in both splits. Separating speakers gives you a better measure of how well the model generalizes. The training split is the data the model learns from. The validation split is held back and used only to test how well the model performs on unseen examples.
Append this to the same train_sentiment_model.py file:
import random
# Split by speaker so the same actor is not in both training and validation.
actors = sorted(df["actor"].unique())
random.seed(42)
random.shuffle(actors)
val_count = max(1, int(0.2 * len(actors)))
val_actors = set(actors[:val_count])
train_actors = set(actors[val_count:])
train_df = df[df["actor"].isin(train_actors)].reset_index(drop=True)
val_df = df[df["actor"].isin(val_actors)].reset_index(drop=True)
print(f"Training samples: {len(train_df)}")
print(f"Validation samples: {len(val_df)}")
Step 2.3 - Load the feature extractor and model
This step loads the HuBERT feature extractor and initializes a sequence classification model. The pre-trained HuBERT base model provides a strong starting point for transfer learning on speech sentiment classification. The feature extractor prepares raw audio in the format expected by the model. The HuBERT model then uses those inputs to predict one of the target sentiment classes.
Append this below the previous code in train_sentiment_model.py:
from transformers import AutoFeatureExtractor, HubertForSequenceClassification
MODEL_NAME = "facebook/hubert-base-ls960"
# The label list defines the numeric class order used during training.
labels = ["angry", "happy", "neutral"]
# Use the HuBERT feature extractor that matches the pretrained checkpoint.
feature_extractor = AutoFeatureExtractor.from_pretrained(MODEL_NAME)
model = HubertForSequenceClassification.from_pretrained(
    MODEL_NAME,
    num_labels=len(labels),
    id2label={i: label for i, label in enumerate(labels)},
    label2id={label: i for i, label in enumerate(labels)},
Step 2.4 - Train and evaluate the model
This step performs the core training pass: load audio, extract features, compute loss, and update the model weights. For clarity, this example uses a simple per-sample training loop rather than batching with a DataLoader. During training, the model compares its predictions with the correct labels and updates its weights to reduce the error. After each epoch, the validation loop checks how well the model performs on held-out speakers.
For better performance in a production training pipeline, you would typically use batching and a PyTorch DataLoader.
import librosa
import torch
def load_audio(path):
    # Resample audio to 16 kHz, the sampling rate expected by HuBERT.
    return librosa.load(path, sr=16000)[0]
if torch.cuda.is_available():
    device = torch.device("cuda")
elif torch.backends.mps.is_available():
    device = torch.device("mps")
else:
    device = torch.device("cpu")
model.to(device)
optimizer = torch.optim.AdamW(model.parameters(), lr=2e-5)
EPOCHS = 4
for epoch in range(EPOCHS):
    print(f"Epoch {epoch + 1}/{EPOCHS}")
    # Switch back to training mode at the start of each epoch.
    model.train()
    for i, (_, row) in enumerate(train_df.iterrows(), start=1):
        audio = load_audio(row["path"])
        # Convert raw waveform into model input tensors.
        inputs = feature_extractor(
            audio,
            sampling_rate=16000,
            return_tensors="pt"
        inputs = {k: v.to(device) for k, v in inputs.items()}
        # Convert the string label into a class index.
        label = torch.tensor([labels.index(row["emotion"])]).to(device)
        loss = model(**inputs, labels=label).loss
        loss.backward()
        optimizer.step()
        optimizer.zero_grad()
        if i % 50 == 0:
            print(f"Processed {i} training samples")
    model.eval()
    correct = 0
    with torch.no_grad():
        for _, row in val_df.iterrows():
                audio,
                return_tensors="pt"
            logits = model(**inputs).logits
            pred = logits.argmax(dim=-1).item()
            if pred == labels.index(row["emotion"]):
                correct += 1
    accuracy = correct / max(1, len(val_df))
    print(f"Validation accuracy: {accuracy:.2f}")
At the end of this step, you’ll have a trained model and a simple validation accuracy printed after each epoch. You should typically see validation accuracy improve over time, although the exact values will vary depending on randomness and hardware.
Step 2.5 - Save the model
Save both the trained model and the feature extractor so they can be reused later for inference and ONNX export. Keeping them together helps avoid preprocessing mismatches. This is an important final step because the model weights alone are not enough. You also need the matching feature extractor so inference uses the same preprocessing as training.
Append this at the end of train_sentiment_model.py:
SAVE_DIR = "models/hubert_vsa_ravdess"
os.makedirs(SAVE_DIR, exist_ok=True)
# Save both the trained model and the preprocessing configuration.
model.save_pretrained(SAVE_DIR)
feature_extractor.save_pretrained(SAVE_DIR)
print("Training complete. Model saved successfully.")
print(f"Saved model to {SAVE_DIR}")
After this step, the trained model should be saved in models/hubert_vsa_ravdess.
Full training script
The following script combines the previous steps into one runnable example. If you already built train_sentiment_model.py using Steps 2.1 to 2.5, you can skip this section. If not, copy this full script into train_sentiment_model.py and run it from the root of your project.
import os
import random
import zipfile
import librosa
import pandas as pd
import torch
# Configuration for dataset download, training, and model export.
EPOCHS = 4
data = []
        continue
            # RAVDESS stores the emotion label in the filename tokens.
                data.append(
                        "actor": actor,
                        "path": os.path.join(actor_path, f),
print(df.head())
random.seed(42)
    MODEL_NAME,
else:
model.to(device)
    # Load and resample audio to the input rate expected by HuBERT.
    model.train()
        # Convert raw audio into tensors the model can consume.
            audio,
            return_tensors="pt",
        # Map the label name to its numeric class ID.
        loss.backward()
        optimizer.step()
        if i % 50 == 0:
    model.eval()
    correct = 0
                audio,
                correct += 1
Run the training script:
python train_sentiment_model.py
In this section, you:
  • Downloaded and prepared the RAVDESS speech emotion dataset
  • Fine-tuned a HuBERT model for voice sentiment classification
  • Validated the model’s accuracy on neutral, happy, and angry emotions
  • Saved the trained model and feature extractor for inference
You now have a trained voice sentiment model ready for deployment. In the next section, you’ll export this model to ONNX format and apply int-8 quantization to optimize it for efficient on-device inference.
