# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/)
- [Set up your environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/1-prerequisites/)
- [Overview](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/2-overview/)
- [Build the Voice Assistant](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/3-build/)
- [Run the Voice Assistant](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/4-run/)
- [KleidiAI](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/5-kleidiai/)
- [Benchmark Voice Assistant](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/6-benchmark/)
- [Performance](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/7-performance/)
- [Performance with Streamline](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/8-performance-with-streamline/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/voice-assistant/_next-steps/)
## Explore related resources
- [Accelerate Generative AI workloads using KleidiAI](https://learn.arm.com/learning-paths/cross-platform/kleidiai-explainer)
- [LLM inference on Android with KleidiAI, MediaPipe, and XNNPACK](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/kleidiai-on-android-with-mediapipe-and-xnnpack/)
- [Vision LLM inference on Android with KleidiAI and MNN](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/vision-llm-inference-on-android-with-kleidiai-and-mnn/)
## Review frequently asked questions
### How do I know Android Studio can deploy the app to my phone?
Enable developer mode, connect your phone with USB, and confirm that it appears as a running device in the Android Studio toolbar. Select the device, then select **Run** to install and launch the Voice Assistant.
### What should I check if the build fails?
If the build fails while downloading, verify that `python3` version 3.9 or later and `git` are installed, and try the Android Studio build again. The first build might take longer while it downloads additional dependencies.
### What result should I expect when I run the Voice Assistant?
Tap **Press to talk** in Chat mode and speak your request. The app transcribes your audio, sends the text to its LLM, and displays the response. To hear the response, enable **Speech generation**, which is disabled by default.
### Do I need to change any settings to use KleidiAI in this project?
On Arm platforms, the default build includes KleidiAI support. To compare against a build without it, add `-PkleidiAI=false` to `./gradlew build` or set `kleidiAI=false` in `gradle.properties`.
### How can I check SME2-related behavior or performance on my device?
To compare SME2 performance, build the LLM benchmark once with `-DMNN_SME2=OFF` and again without that setting, which enables SME instructions by default. You can also capture a profile in Arm Streamline to confirm SME2 kernel activity during LLM execution.
