You can also benchmark the LLM functionality on Android phone outside of RTVA application. For this, you can use the Large Language Models repository:
https://github.com/Arm-Examples/LLM-Runner
and build for your chosen LLM backend, ensure that NDK_PATH is set properly. SME kernels are enabled by default, so let’s first build with SME disabled:
cmake --preset=x-android-aarch64 -B build/ -DBUILD_BENCHMARK=ON -DLLM_FRAMEWORK=mnn -DMNN_SME2=OFF
cmake --build ./build
For troubleshooting any build issues, refer to large-language-models README
Now that you have all the libraries and executables needed, you can create a benchmarking directory and push the needed libraries to the phone:
adb shell mkdir /data/local/tmp/benchmark_test/
adb push build/lib/* /data/local/tmp/benchmark_test/
build/lib/archive/: 9 files pushed. 140.0 MB/s (36970298 bytes in 0.252s)
build/lib/libMNN.so: 1 file pushed. 139.5 MB/s (4973176 bytes in 0.034s)
build/lib/libarm-llm-jni.so: 1 file pushed. 153.8 MB/s (3832152 bytes in 0.024s)
11 files pushed. 137.0 MB/s (45775626 bytes in 0.319s)
This will copy the executables you can run:
adb push build/bin/* /data/local/tmp/benchmark_test/
build/bin/arm-llm-bench-cli: 1 file pushed. 134.3 MB/s (3415344 bytes in 0.024s)
build/bin/llm-cpp-tests: 1 file pushed. 157.7 MB/s (17783848 bytes in 0.108s)
build/bin/llm_bench: 1 file pushed. 22.6 MB/s (85688 bytes in 0.004s)
build/bin/llm_demo: 1 file pushed. 12.6 MB/s (34656 bytes in 0.003s)
4 files pushed. 141.7 MB/s (21319536 bytes in 0.143s)
Finally, copy the models to benchmark:
adb push resources_downloaded/models/mnn/ /data/local/tmp/benchmark_test/
To make sure the screen stays on and the CPU is not throttled use the following commands:
adb shell svc power stayon true
adb shell dumpsys deviceidle disable
You can now run the executable in ADB shell, providing the path to libraries and the number of iterations to benchmark:
adb shell
cd /data/local/tmp/benchmark_test/
LD_LIBRARY_PATH=./ ./arm-llm-bench-cli -m mnn/llama-3.2-1b/ -i 128 -o 128 -t 1 -n 5 -w 1
As you see in the output, the flags used by executable are listed below:
-m : path to the specific model or a directory with model and configuration files-i : number input tokens to use-o : number output tokens to generate-t : number of threads to use-n : number of iterations used for benchmarking-w : number of warmup iterations, not included in benchmarking
=== ARM LLM Benchmark ===
Parameters:
model_path : mnn/llama-3.2-1b/
num_input_tokens : 128
num_output_tokens : 128
num_threads : 1
num_iterations : 5
num_warmup : 1
======= Results =========
| Framework | Threads | Test | Performance |
| mnn | 1 | pp128 | 196.446 ± 0.377 (t/s) |
| mnn | 1 | tg128 | 27.222 ± 0.369 (t/s) |
| mnn | 1 | TTFT | 687.931 ± 2.279 (ms) |
| mnn | 1 | Total | 5354.526 ± 63.163 (ms) |
To get benchmark numbers with use of SME kernels, you can rerun the full “Benchmarking LLM on Android phone” section without setting MNN_SME2 to OFF. Omitting the MNN_SME2 flag enables SME instructions by default.:
The table table shows the measurements taken on a Vivo X300 Android phone:
| LLM Framework | Model | Threads | Without SME2 | With SME2 | Uplift |
| mnn | qwen25vl-3b | 1 | 85 | 134 | 57.65 % |
| 2 | 95 | 140 | 47.37 % | ||
| llama-3.2-1B | 1 | 196 | 339 | 72.96 % | |
| 2 | 275 | 396 | 44.00 % | ||
| llama.cpp | qwen-2-VL | 1 | 113 | 146 | 29.20 % |
| 2 | 92 | 139 | 51.09 % | ||
| llama-3.2-1B | 1 | 148 | 173 | 16.89 % | |
| 2 | 124 | 191 | 54.03 % | ||
| phi-2 | 1 | 58 | 77 | 32.76 % | |
| 2 | 46 | 60 | 30.43 % |
The Android system enforces throttling, so your own results may vary slightly.
These measurements show how fast the model processes (encodes) 128 input tokens when running on a single CPU thread. As the results illustrate, SME2 delivers a significant performance boost even when using just one or two CPU cores on an Android phone, meaning faster processing without needing to involve multiple CPU cores.
To summarize, KleidiAI simplifies development by abstracting away low-level optimization: developers can write high-level code while the KleidiAI library selects the most efficient implementation at runtime based on the target hardware. This is possible thanks to its deeply optimized micro-kernels tailored for Arm architectures.
As newer versions of the architecture become available, KleidiAI becomes even more powerful: simply updating the library allows applications like the multimodal Voice Assistant to take advantage of the latest architectural improvements such as SME2, without requiring any code changes. This means better performance on newer devices with no additional effort from developers.
