KleidiAI
The Voice Assistant application combines local LLM inference and speech recognition - both computationally demanding tasks that have been optimized for Arm platforms using the efficient libraries Llama.cpp and KleidiAI library .
KleidiAI is an open-source library of highly tuned micro-kernels for AI workloads on Arm CPUs. These routines are optimized to exploit specific Arm hardware features for maximum performance.
The KleidiAI library is designed for easy integration into C or C++ machine learning (ML) and AI frameworks. Developers looking to incorporate specific micro-kernels into their projects can include the corresponding .c and .h files associated with those micro-kernels and a common header file.
Compare the performance without KleidiAI
By default, the Voice Assistant is built with KleidiAI support on Arm platforms, but this can be disabled if you want to compare the performance to a raw implementation.
To disable KleidiAI during build:
  • Add -PkleidiAI=false to your Gradle command:./gradlew build -PkleidiAI=false.
  • Or, add this to your top-level gradle.properties file: kleidiAI=false.
Now that you can build the Voice Assistant with and without KleidiAI, you can test out the benchmarking functionality it provides.
