Explore related resources
Give feedback
AI-assisted
Close
Which NDK and CMake do I need, and how do I install them?
To match the tested setup, use Android NDK 28.0.12916984 and CMake 4.0.0-rc1. In Android Studio, select Tools > SDK Manager, open SDK Tools, then select NDK (Side by side) and CMake. On Ubuntu or Debian, install cmake and git-lfs with the provided command.
How do I clone and open the project in Android Studio?
Run git clone https://gitlab.arm.com/kleidi/kleidi-examples/vision-language-models. In Android Studio, select File > Open, choose the vision-language-models directory, and select Open. Android Studio then builds the project.
Where should I put the example image and what name should it have?
Rename the image to example.png, then run adb push example.png /data/local/tmp/ to copy it to your device.
How do I compare inference with and without KleidiAI micro-kernels?
Build and run the MNN command-line demo without KleidiAI first. Then add the CPU_ENABLE_KLEIDIAI runtime hint, rebuild the binaries, replace them on your device, and run the same inference command again to compare the reported timings.
When is the model converted to MNN, and how do I know it worked?
Model conversion is optional. By default, you download the pre-quantized Qwen2.5-VL-3B-Instruct-MNN model. If you convert the model with llmexport, verify that the Qwen2.5-VL-3B-Instruct-convert-4bit-64qblock directory is at least 2 GB.
Return to Mobile, Graphics, and Gaming
