Explore related resources
Give feedback
AI-assisted
Close
Where do I switch the project to the unoptimized version?
Open Assets/BurstNeonCollisions/Scripts/CollisionCalculationScript.cs and change line 66 to public const Mode codeMode = Mode.Plain; to select the unoptimized mode for your initial measurements.
How do I enable or update the Burst compiler in Unity?
From Window, select Packet Management > Package Manager. Set Packages to Unity Registry, search for Burst, select it, and select Install if it’s not already ticked.
Which Unity and Burst versions should I use?
To match the environment used in the Learning Path, use Unity v6.3 and Burst 1.8.28.
Which parts of the sample are affected by the optimization steps?
Review the character-wall and character-character collision functions. In Plain mode, DoWallsPlain() loops through all characters and walls, while DoCharactersPlain() checks each character against the others; the code assumes a character can hit up to two walls.
Why should I compare Burst and Neon performance?
Burst can auto-vectorize your code efficiently, so hand-written Neon doesn’t always improve performance. Profile your app before and after adding Neon. If performance doesn’t improve, Burst might produce better-optimized code.
Return to Mobile, Graphics, and Gaming
