Optimize Unity applications on Android using Neon intrinsics
Set up
Arm Neon and the Unity Burst compiler
The sample project
The plain (unoptimized) code
The optimizations
Collecting performance data
Analyzing the performance data
Profiling best practice
Appendix
Capturing reliable performance data
Here are a few things you can do to improve the reliability of performance data you capture from the Profiler:
Try to capture representative and repeatable captures
Turn off performance scaling if you can (which may involve root permissions on your device) as the device may be varying the CPU frequency to adapt to varying loads and temperatures
Use the same (or matching) device(s) when capturing and comparing multiple datasets
Performance data can be logged outside of the Unity Editor - you can log data from within your own C# scripts
Make use of profiling markers to highlight the code you want to measure in the Profiler and Analyzer
