Explore related resources
Give feedback
AI-assisted
Close
Where do I get the Droid OS image for Orange Pi 5?
Go to the Orange Pi 5 support page and select Orange Pi OS(Droid) > TF Card Image. In Google Drive, download the latest image for Orange Pi 5.
How do I write the Droid OS image to the microSD card?
On Windows, extract the downloaded .tar.gz, then the resulting .tar, to produce a .img file. Use SDDiskTool_v1.72 to write the .img file to the microSD card.
What should I check if Android isn't available in Unity Build Settings?
In Unity Hub, select Installs, find the Unity version for your project, select its three-dot menu, then select Add Modules. Select Android Build Support and all its sub-items. In Unity, select File > Build Settings, choose Android, and restart Unity when prompted.
What output file should I expect from the Unity build?
When you build for Android, choose a folder for the generated APK file. Transfer that APK to the Orange Pi 5 and install it on Droid OS.
How can I transfer the APK to the Orange Pi 5?
Use a USB thumb drive if its file system is compatible with Droid OS, copy the file onto the microSD card if formats are compatible, or upload it to a cloud drive and download it on the Orange Pi. If you use a cloud service, ensure the board has network access.
Return to Mobile, Graphics, and Gaming
