Give feedback
AI-assisted
Close
How do I restore the environment if I open a new terminal?
From your executorch directory, run source .venv/bin/activate and then source examples/arm/arm-scratch/setup_path.sh before building or running the model.
Do I need to train Swin2SR or prepare calibration images?
No. You’ll export a pretrained ×2 checkpoint pinned to a specific revision. The export uses --quantization-mode none, so you don’t need calibration images.
Why do I need both Swin2SR PTE and JSON files?
The .pte file contains your executable model, while the .json file tells the image helper how to read the input and reconstruct the output. Keep them in the same directory with the same base name.
Can I use my own image with the exported program?
Yes, if your image is 64 × 64 pixels and RGB. For a different input size, export a matching program first. The helper doesn’t resize or tile images automatically.
How do I know that the image run succeeded?
Look for Saved super-resolved image to in the terminal output. Check that your generated image is 128 × 128 and shows the same scene without obvious corruption. You can compare it with the high-resolution reference, but the visual check isn’t a quality benchmark or performance result.
Return to Mobile, Graphics, and Gaming
