Upscale an image with Swin2SR and Arm VGF
Build the host runner
ExecuTorch’s executor_runner loads your .pte program and executes it. Continue from the same terminal in your executorch directory.
If you open a new terminal, you’ll have to restore the environment:
source .venv/bin/activate
source examples/arm/arm-scratch/setup_path.sh
Use the repository’s build script to enable Vulkan Graph Format (VGF) and the runtime libraries that it needs:
bash backends/arm/scripts/build_executor_runner_vkml.sh \
--output=swin2sr-work/build
This builds a release executable at swin2sr-work/build/executor_runner. You need to build the executable only once.
Upscale the image
Run the image helper with your exported program, the host runner, and the 64 × 64 input:
python examples/arm/super_resolution_example_vgf/runtime/run_super_resolution.py \
--model-path swin2sr-work/swin2sr.pte \
--runner swin2sr-work/build/executor_runner \
--input-image swin2sr-work/runtime/demo_lr_64.png \
--output-image swin2sr-work/runtime/demo_sr_128.png
The output is similar to:
Saved super-resolved image to /home/ubuntu/executorch/swin2sr-work/runtime/demo_sr_128.png
The path reflects your checkout location.
The helper converts the image into a tensor — a numerical representation of its pixels. It runs the model and saves the output tensor as a PNG. A successful run ends with Saved super-resolved image to, followed by the full path to demo_sr_128.png.
Your input needs to be exactly 64 × 64 pixels. If you see an expected (1, 3, 64, 64) error, check that you used demo_lr_64.png, not the larger reference image.
You’ve executed the exported program and saved its 128 × 128 output.
Next, you’ll open the result and compare it with the input and high-resolution reference.
