Understand the default adapter
The unmodified starter application uses a mock runner so that its interface can build without a model runtime. When you applied the SmolLM2 example, you replaced that mock setup with ExecuTorchTextGenerationAdapter with SmolLM2 360M Instruct.
An adapter is the application code between the shared Android interface and a particular model runtime. ui/MainActivity.kt reads the selected entry from model_catalog.json. inference/RuntimeRunnerFactory.kt creates the adapter named by its runtime value.
The adapter then:
  • Checks that the expected model, tokenizer, configuration, and template files are present
  • Converts the prompt into the inputs required by the runtime
  • Calls the runtime packaged in the APK
  • Decodes and cleans the generated tokens for display
The downloaded model package isn’t an Android executable. Gradle packages the runtime’s Java and native libraries in the APK. The adapter uses those libraries to load and execute the model artifact stored in the application’s private directory.
Choose a text-generation path
The application includes three validated text-generation examples that share the interface and deployment flow. However, each needs an adapter because its runtime API, model format, tokenizer handling, and output contract differ.
The following table describes the paths:
PathCatalog runtimeAdapterModel packageWhat it demonstrates
SmolLM2 with ExecuTorchexecutorchinference/models/smollm2/ExecuTorchTextGenerationAdapter.pte, configuration, tokenizer, and chat templateThe recommended default and smallest validated generation example.
TinyLlama with ONNX Runtime GenAIonnxruntimeinference/models/tinyllama/OnnxTextGenerationAdapterONNX model directory, configuration, tokenizer, and chat templateA directory-based GenAI package with an additional Android AAR dependency.
Llama 3.2 with ONNX Runtime GenAIonnxruntimeinference/models/llama32/OnnxTextGenerationAdapterONNX model directory, configuration, tokenizer, and chat templateThe same GenAI runtime flow with the Llama 3.2 package.
The repository also contains inference/models/bge/LiteRtEmbeddingAdapter for the catalog runtime litert. That adapter runs the BGE text-embedding workload and returns vectors rather than generated text, so it is listed separately from the text-generation paths.
You’ve already completed the recommended ExecuTorch path. Choose one of the alternative paths only if you want to compare the integration process with another runtime. The model changes with the runtime, so this isn’t a controlled performance comparison.
Keep the default ExecuTorch path
No additional setup is needed. The SmolLM2 example adds org.pytorch:executorch-android:1.1.0, registers the executorch catalog entry, and supplies the adapter that loads the .pte program.
During Load, the adapter:
  • Checks the package paths
  • Creates the tokenizer
  • Loads the program
  • Makes a probe call to confirm that the output matches the expected vocabulary
This checks compatibility with the adapter and doesn’t evaluate the model’s language quality or accuracy.
Prepare the ONNX Runtime GenAI path
The ONNX Runtime GenAI examples use com.microsoft.onnxruntime:onnxruntime-android:1.27.0 and the official ONNX Runtime GenAI Android AAR. Download the official pre-compiled ONNX Runtime GenAI Android AAR before you apply an ONNX Runtime GenAI adapter.
export WORK_DIR="$HOME/text-to-text-android"
mkdir -p "$WORK_DIR"
export ONNX_GENAI_AAR="$WORK_DIR/onnxruntime-genai-release.aar"
curl --fail --location \
    "https://github.com/microsoft/onnxruntime-genai/releases/download/v0.16.0/onnxruntime-genai-android-0.16.0.aar" \
    --output "$ONNX_GENAI_AAR"
test -f "$ONNX_GENAI_AAR"
$WORK_DIR = Join-Path $HOME "text-to-text-android"
New-Item -ItemType Directory -Force -Path $WORK_DIR
$ONNX_GENAI_AAR = Join-Path $WORK_DIR "onnxruntime-genai-release.aar"
Invoke-WebRequest `
    -Uri "https://github.com/microsoft/onnxruntime-genai/releases/download/v0.16.0/onnxruntime-genai-android-0.16.0.aar" `
    -OutFile $ONNX_GENAI_AAR
Test-Path $ONNX_GENAI_AAR
Create a separate project and select one ONNX Runtime GenAI example:
cd "$WORK_DIR"
git clone https://github.com/arm-education/ai-portal-android-app-text-to-text.git \
    ai-portal-android-app-text-to-text-onnx
cd ai-portal-android-app-text-to-text-onnx
# Choose one validated ONNX Runtime GenAI example.
export ONNX_EXAMPLE="tinyllama-onnx-genai"
export MODEL_ID="tinyllama-1-1b-chat-onnx-genai-int4-kquantlast-emb-int8-vivo-x300"
# Or use Llama 3.2 instead:
# export ONNX_EXAMPLE="llama-3-2-onnx-genai"
# export MODEL_ID="llama-3-2-1b-instruct-onnx-genai-int4-kquantlast-emb-int8-vivo-x300"
cp -R "adapter-examples/$ONNX_EXAMPLE/app/." app/
mkdir -p app/libs
cp "$ONNX_GENAI_AAR" app/libs/onnxruntime-genai-release.aar
export MODEL_DIR="../model-onnx"
../.hf-venv/bin/hf download "Arm/$MODEL_ID" --local-dir "$MODEL_DIR"
Set-Location $WORK_DIR
git clone https://github.com/arm-education/ai-portal-android-app-text-to-text.git `
Set-Location ai-portal-android-app-text-to-text-onnx
$ONNX_EXAMPLE = "tinyllama-onnx-genai"
$MODEL_ID = "tinyllama-1-1b-chat-onnx-genai-int4-kquantlast-emb-int8-vivo-x300"
# $ONNX_EXAMPLE = "llama-3-2-onnx-genai"
# $MODEL_ID = "llama-3-2-1b-instruct-onnx-genai-int4-kquantlast-emb-int8-vivo-x300"
Copy-Item -Path "adapter-examples\$ONNX_EXAMPLE\app\*" `
    -Destination "app" -Recurse -Force
New-Item -ItemType Directory -Force -Path "app\libs"
Copy-Item -Path $ONNX_GENAI_AAR -Destination "app\libs\onnxruntime-genai-release.aar" -Force
$MODEL_DIR = "..\model-onnx"
..\.hf-venv\Scripts\hf.exe download "Arm/$MODEL_ID" --local-dir $MODEL_DIR
The commands above copy the generated AAR to app/libs/onnxruntime-genai-release.aar. Keep every file in the downloaded ONNX model directory together, including external model data, genai_config.json, tokenizer files, and the chat template.
Build and run the selected alternative
The selected ONNX Runtime GenAI alternative now follows the same workflow: build the APK, install the APK, copy the chosen model package to the directory named by its catalog ID, and start the application.
Continue in the same terminal so that MODEL_ID and MODEL_DIR remain set:
export ANDROID_PACKAGE="com.arm.learningpath.texttotext"
chmod +x gradlew
./gradlew :app:assembleDebug :app:lintDebug
adb install -r app/build/outputs/apk/debug/app-debug.apk
adb shell "mkdir -p /data/local/tmp/text-to-text-models/$MODEL_ID"
adb push "$MODEL_DIR/." "/data/local/tmp/text-to-text-models/$MODEL_ID/"
adb shell "run-as $ANDROID_PACKAGE mkdir -p files/models/$MODEL_ID"
adb shell "run-as $ANDROID_PACKAGE cp -r /data/local/tmp/text-to-text-models/$MODEL_ID/. files/models/$MODEL_ID/"
adb shell "run-as $ANDROID_PACKAGE find files/models/$MODEL_ID -maxdepth 4 -type f"
adb shell am start -n "$ANDROID_PACKAGE/.ui.MainActivity"
$ANDROID_PACKAGE = "com.arm.learningpath.texttotext"
.\gradlew.bat :app:assembleDebug :app:lintDebug
adb push "$MODEL_DIR\." "/data/local/tmp/text-to-text-models/$MODEL_ID/"
In the application, do the following:
  1. Select the model from the catalog.
  2. Select Load.
  3. Enter the same privacy prompt used for SmolLM2.
  4. Select Run.
A successful result is a relevant completion without prompt echoes, control tokens, or runtime diagnostic text.
You’ve now identified the default real adapter and distinguished the validated text-generation integrations. You also optionally repeated the common Android deployment workflow with ONNX Runtime GenAI.
Next, you’ll verify on-device text generation.
