In this section, you will cross-compile the audio generation application for Android and run it on an Android device with an Arm CPU.
Start a fresh virtual environment to avoid dependency conflicts from earlier steps.
cd $WORKSPACE/ML-examples/kleidiai-examples/audiogen-et/
python3.10 -m venv android-venv
source android-venv/bin/activate
If you haven’t already installed ExecuTorch, install it now:
pip install executorch==1.0.0
Set the EXECUTORCH_MODELS_PATH environment variable to the directory containing your exported ExecuTorch models:
export EXECUTORCH_MODELS_PATH=$WORKSPACE/ML-examples/kleidiai-examples/audiogen-et
Download Android NDK r27c for your host platform. Navigate to the app directory first:
cd app
wget https://dl.google.com/android/repository/android-ndk-r27c-linux.zip
unzip android-ndk-r27c-linux.zip
curl https://dl.google.com/android/repository/android-ndk-r27c-darwin.zip -o android-ndk-r27c-darwin.zip
unzip android-ndk-r27c-darwin.zip
Set the NDK_PATH environment variable to the extracted NDK directory:
export NDK_PATH=$(pwd)/android-ndk-r27c
If you extracted the NDK to a different directory, update NDK_PATH accordingly.
Create a build directory and navigate into it:
mkdir android-build && cd android-build
Run CMake with the Android toolchain configuration:
cmake -DCMAKE_TOOLCHAIN_FILE=$NDK_PATH/build/cmake/android.toolchain.cmake -DANDROID_ABI=arm64-v8a ..
This command configures the build to use the Android NDK toolchain and target the arm64-v8a architecture.
Build the application:
make -j8
The build process creates an audiogen executable for Android in the android-build directory.
Ensure adb is installed and your Android device is connected by running adb devices.
Use adb to transfer the application and model files to your Android device.
Create a directory on the device:
adb shell mkdir -p /data/local/tmp/app
/data/local/tmp directory is writable without root access and commonly used for testing native binaries.Push the application executable:
adb push audiogen /data/local/tmp/app
Push the three model files:
adb push $EXECUTORCH_MODELS_PATH/dit_model.pte /data/local/tmp/app
adb push $EXECUTORCH_MODELS_PATH/autoencoder_model.pte /data/local/tmp/app
adb push $EXECUTORCH_MODELS_PATH/conditioners_model.pte /data/local/tmp/app
Download the SentencePiece tokenizer model:
wget https://huggingface.co/google-t5/t5-base/resolve/main/spiece.model
adb push spiece.model /data/local/tmp/app
curl -L https://huggingface.co/google-t5/t5-base/resolve/main/spiece.model -o spiece.model
Connect to your Android device using adb:
adb shell
Navigate to the application directory:
cd /data/local/tmp/app
Run the audiogen application with an example prompt:
./audiogen -m . -p "warm arpeggios on house beats 120BPM with drums effect" -t 4
The arguments are:
-m): Directory containing the models and tokenizer (. for current directory)-p): Text description of the desired audio-t): Number of CPU threads to use (adjust based on your device)The application generates a short audio sample based on your prompt.
Exit the adb shell by typing exit, then pull the generated audio file from the device:
adb pull /data/local/tmp/app/warm_arpeggios_on_house_beats_120bpm_with_drums_effect_99.wav
Play the audio file on your development machine or transfer it to your Android phone. Experiment with different prompts to generate various audio samples on your Android device. The application uses ExecuTorch with XNNPack and Arm KleidiAI optimizations to deliver efficient inference on Arm CPUs.
Try different prompts such as:
The Stable Audio Open Small model works best with clear, descriptive prompts that include musical elements, tempo, and atmosphere.
You’ve successfully deployed the Stable Audio Open Small model on Android using ExecuTorch. Throughout this Learning Path, you converted the three model submodules (Conditioners, DiT, and AutoEncoder) to ExecuTorch format, built an optimized audio generation application, and ran it on an Arm-based Android device. The application leverages ExecuTorch with XNNPack and Arm KleidiAI to deliver efficient on-device audio generation, enabling real-time text-to-audio synthesis without requiring cloud connectivity. Integrate this capability into mobile applications or continue exploring audio generation with different prompts and configurations.
