Create a virtual environment
Create and activate a Python virtual environment to manage dependencies. Python 3.10 is recommended for compatibility with the required packages:
cd $WORKSPACE/ML-examples/kleidiai-examples/audiogen-et/
python3.10 -m venv .venv
source .venv/bin/activate
Install ExecuTorch
Install the ExecuTorch package version 1.0.0:
pip install executorch==1.0.0
Alternatively, clone the ExecuTorch repository and run the installation script:
git clone https://github.com/pytorch/executorch.git
cd executorch
git checkout v1.0.0
bash ./install_executorch.sh
cd ..
Install Stable Audio Tools
Install the Stable Audio Open tools dependency:
pip install git+https://github.com/Stability-AI/stable-audio-tools.git@31932349d98c550c48711e7a5a40b24aa3d7c509
Export the model submodules
Export the three model submodules to ExecuTorch format using the provided script from the audiogen-et directory:
python ./scripts/export_sao.py --ckpt_path $WORKSPACE/model.ckpt --model_config $WORKSPACE/model_config.json
The script converts all three submodules (Conditioners, DiT, and AutoEncoder) and exports them to .pte files.
Troubleshooting conversion issues
If you see a FileNotFoundError related to missing .fbs files during conversion:
        FileNotFoundError: [Errno 2] No such file or directory: '../kleidiai-examples/audiogen-et/scripts/executorch/exir/_serialize/program.fbs'
Run these commands to copy the required schema files:
export EXECUTORCH_ROOT=<PATH-TO-EXECUTORCH>
cp $EXECUTORCH_ROOT/schema/program.fbs $EXECUTORCH_ROOT/exir/_serialize/program.fbs
cp $EXECUTORCH_ROOT/schema/scalar_type.fbs $EXECUTORCH_ROOT/exir/_serialize/scalar_type.fbs
Then retry the export script.
Verify exported models
After successful conversion, three .pte model files are created in the current directory:
  • conditioners_model.pte
  • dit_model.pte
  • autoencoder_model.pte
These files are required to run the audio generation application on Android or macOS.
Verify the files were created:
ls -lh conditioners_model.pte dit_model.pte autoencoder_model.pte
The files should be in $WORKSPACE/ML-examples/kleidiai-examples/audiogen-et/.
You’ve installed ExecuTorch and the Stable Audio Tools dependencies, then converted the three Stable Audio Open Small submodules (Conditioners, DiT, and AutoEncoder) to ExecuTorch format. Next, you’ll build the audio generation application for your target platform (Android or macOS).
