# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/)
- [Set up your development environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/1-prerequisites/)
- [Download and test the model](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/2-testing-model/)
- [Convert Stable Audio Open Small model to LiteRT](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/3-converting-model/)
- [Build LiteRT](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/4-building-litert/)
- [Create a simple program for Android target](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/5-creating-simple-program-for-android/)
- [Create a simple program for macOS target](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/6-creating-simple-program-for-macos/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/_next-steps/)
## Explore related resources
- [Stability AI and Arm Collaborate to Release Stable Audio Open Small, Enabling Real-World Deployment for On-Device Audio Generation](https://stability.ai/news/stability-ai-and-arm-release-stable-audio-open-small-enabling-real-world-deployment-for-on-device-audio-control)
- [Unlocking audio generation on Arm CPUs to all: Running Stable Audio Open Small with KleidiAI](https://community.arm.com/arm-community-blogs/b/ai-blog/posts/audio-generation-arm-cpus-stable-audio-open-small-kleidiai)
- [Fast Text-to-Audio Generation with Adversarial Post-Training](https://arxiv.org/abs/2505.08175)
## Review frequently asked questions
### How do I know the model download is complete before conversion?
Verify that `model_config.json` and `model.ckpt` are in your workspace directory. Run the listed `ls` command before you start conversion.
### Where do I run CMake to build the Android app?
From your workspace, navigate to `ML-examples/kleidiai-examples/audiogen/app` and create a build directory. Run CMake from that build directory.
### Which Android ABI should I use for Arm targets?
Set `ANDROID_ABI=arm64-v8a` in the CMake command for the Android build.
### What paths do I pass to CMake after building LiteRT?
Build LiteRT and FlatBuffers, then configure CMake with `TF_INCLUDE_PATH`, `TF_LIB_PATH`, and `FLATBUFFER_INCLUDE_PATH`.
### What result should I expect when running the program on the device?
Run `audiogen` on the device with a text prompt. After inference, pull `/data/local/tmp/app/output.wav` to your host machine.
