As a final step, you’ll build a simple program that runs inference on all three submodules directly on a macOS device.
The program takes a text prompt as input and generates an audio file as output.
cd $WORKSPACE/ML-examples/kleidiai-examples/audiogen/app
mkdir build && cd build
Ensure the NDK path is set correctly and build with cmake:
cmake -DCMAKE_POLICY_VERSION_MINIMUM=3.5 \
-DTF_INCLUDE_PATH=$TF_SRC_PATH \
-DTF_LIB_PATH=$TF_SRC_PATH/bazel-bin/tensorflow/lite \
-DFLATBUFFER_INCLUDE_PATH=$TF_SRC_PATH/flatc-native-build/flatbuffers/include \
make -j
After the example application builds successfully, a binary file named audiogen is created.
A SentencePiece model is a type of subword tokenizer which is used by the audiogen application, you’ll need to download the spiece.model file from:
cd $LITERT_MODELS_PATH
wget https://huggingface.co/google-t5/t5-base/resolve/main/spiece.model
Verify this model was downloaded to your WORKSPACE.
ls $LITERT_MODELS_PATH/spiece.model
Copy the shared LiteRT dynamic library to the $LITERT_MODELS_PATH.
cp $TF_SRC_PATH/bazel-bin/tensorflow/lite/libtensorflowlite.so $LITERT_MODELS_PATH/
From there, you can then run the audiogen application, which requires just three input arguments:
Play around with the advice from Download and test the model section.
cd $WORKSPACE/ML-examples/kleidiai-examples/audiogen/app/
./build/audiogen $LITERT_MODELS_PATH "warm arpeggios on house beats 120BPM with drums effect" 4
You can now check the generated output.wav and listen to the result.
You should now have gained hands-on experience running the Stable Audio Open Small model with LiteRT on Arm-based devices. This includes setting up the environment, optimizing the model for on-device inference, and understanding how efficient runtimes like LiteRT make low-latency generative AI possible at the edge. You’re now better equipped to explore and deploy AI-powered audio applications on mobile and embedded platforms.
