You’ll now build a simple program that runs inference on all three submodules directly on an Android device.
The program takes a text prompt as input and generates an audio file as output.
cd $WORKSPACE/audio-stale-open-litert/app
mkdir build && cd build
Ensure the NDK path is set correctly and build with cmake:
cmake -DCMAKE_TOOLCHAIN_FILE=$NDK_PATH/build/cmake/android.toolchain.cmake \
-DCMAKE_POLICY_VERSION_MINIMUM=3.5 \
-DANDROID_ABI=arm64-v8a \
-DTF_INCLUDE_PATH=$TF_SRC_PATH \
-DTF_LIB_PATH=$TF_SRC_PATH/bazel-bin/tensorflow/lite \
-DFLATBUFFER_INCLUDE_PATH=$TF_SRC_PATH/flatc-native-build/flatbuffers/include \
cmake --build . -j1
Since the tokenizer used in the audiogen application is based on SentencePiece, you’ll need to download the spiece.model file from:
https://huggingface.co/google-t5/t5-base/tree/main
we will save this model in WORKSPACE
for ease of access.
cp spiece.moel $WORKSPACE
After the SAO example builds successfully, a binary file named audiogen_main
is created.
Now use adb (Android Debug Bridge) to push the necessary files to the device:
adb shell
Create a directory for all the required resources:
cd /data/local/tmp
mkdir audiogen
exit
Push all necessary files into the audiogen
folder on Android:
cd $WORKSPACE/audio-stale-open-litert/app/build
adb shell mkdir -p /data/local/tmp/app
adb push audiogen /data/local/tmp/app
adb push $LITERT_MODELS_PATH/conditioners_float32.tflite /data/local/tmp/app
adb push $LITERT_MODELS_PATH/dit_model.tflite /data/local/tmp/app
adb push $LITERT_MODELS_PATH/autoencoder_model.tflite /data/local/tmp/app
adb push $WORKSPACE/spiece.model /data/local/tmp/app
adb push ${TF_SRC_PATH}/bazel-bin/tensorflow/lite/libtensorflowlite.so /data/local/tmp/app
Finally, run the program on your Android device:
adb shell
cd /data/local/tmp/app
LD_LIBRARY_PATH=. ./audiogen . "warm arpeggios on house beats 120BPM with drums effect" 4
The successful execution of the app will create output.wav
of your chosen audio defined by the prompt, you can pull it back to your host machine and enjoy!
adb pull /data/local/tmp/app/output.wav
