# Build LiteRT
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/)
- [Set up your development environment](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/1-prerequisites/)
- [Download and test the model](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/2-testing-model/)
- [Convert Stable Audio Open Small model to LiteRT](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/3-converting-model/)
- [Build LiteRT](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/4-building-litert/)
- [Create a simple program for Android target](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/5-creating-simple-program-for-android/)
- [Create a simple program for macOS target](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/6-creating-simple-program-for-macos/)
- [Next Steps](https://learn.arm.com/learning-paths/mobile-graphics-and-gaming/run-stable-audio-open-small-with-lite-rt/_next-steps/)
## LiteRT
LiteRT (short for Lite Runtime), formerly known as TensorFlow Lite, is Google’s high-performance runtime for on-device AI. Designed for low-latency, resource-efficient execution, LiteRT is optimized for mobile and embedded environments — making it a natural fit for Arm CPUs running models like Stable Audio Open Small. You’ll build the runtime using the Bazel build tool.
## Build LiteRT libraries
Clone the repository and get the latest modules
cd $WORKSPACE
git clone https://github.com/tensorflow/tensorflow.git tensorflow_src
cd tensorflow_src
Check out the specified commit of TensorFlow, and set the `TF_SRC_PATH`:
git checkout 84dd28bbc29d75e6a6d917eb2998e4e8ea90ec56
export TF_SRC_PATH=$(pwd)
A script is available to configure the `bazel` build environment. Run it to create a custom TFLite build for Android:
> **Reminder**
> Ensure the `NDK_PATH` variable is set to your previously installed Android NDK:
#### For Linux:
export NDK_PATH=$WORKSPACE/android-ndk-r25b/
export ANDROID_NDK_HOME=$NDK_PATH
export PATH=$NDK_PATH/toolchains/llvm/prebuilt/linux-x86_64/bin/:$PATH
#### For macOS:
export PATH=$NDK_PATH/toolchains/llvm/prebuilt/darwin-x86_64/bin/:$PATH
The configuration script is interactive. Run it using the command below, and use the table to set the parameters for this Learning Path use-case.
python3 ./configure.py
| Question        | Input         |
| Please specify the location of python. [Default is $WORKSPACE/bin/python3]:                                          | Enter (default) |
| Please input the desired Python library path to use[$WORKSPACE/lib/python3.10/site-packages]                         | Enter         |
| Do you wish to build TensorFlow with ROCm support? [y/N]                                                             | N (No)       |
| Do you wish to build TensorFlow with CUDA support?        | N             |
| Please specify optimization flags to use during compilation when bazel option “–config=opt” is specified [Default is -Wno-sign-compare]: | Enter         |
| Do you want to use Clang to build TensorFlow? [Y/n]        | N             |
| Would you like to interactively configure ./WORKSPACE for Android builds? [y/N]                                      | y (Yes)      |
| Please specify the home path of the Android NDK to use. [Default is /home/user/Android/Sdk/ndk-bundle]               | Enter         |
| Please specify the (min) Android NDK API level to use. [Default is 21]                                              | 27            |
| Please specify the home path of the Android SDK to use. [Default is /home/user/Android/Sdk]                         | Enter         |
| Please specify the Android SDK API level to use. [Default is 35]                                                     | Enter         |
| Please specify an Android build tools version to use. [Default is 35.0.0]                                           | Enter         |
| Do you wish to build TensorFlow with iOS support? [y/N]:                                                              | n             |
Once the Bazel configuration is complete, you can build LiteRT for your target platform as follows:
#### For Android:
bazel build -c opt --config android_arm64 //tensorflow/lite:libtensorflowlite.so \
    --define tflite_with_xnnpack=true \
    --define=xnn_enable_arm_i8mm=true \
    --define tflite_with_xnnpack_qs8=true \
    --define tflite_with_xnnpack_qu8=true
#### For macOS:
bazel build -c opt --config macos //tensorflow/lite:libtensorflowlite.so \
    --define xnn_enable_arm_i8mm=true \
The final step is to build flatbuffers used by the application:
cd $WORKSPACE/tensorflow_src
mkdir flatc-native-build && cd flatc-native-build
cmake ../tensorflow/lite/tools/cmake/native_tools/flatbuffers
cmake --build .
Now that LiteRT and FlatBuffers are built, you’re ready to compile and deploy the Stable Audio Open Small inference application on your Android or macOS device.
