Stable Audio Open Small is an open-source model optimized for generating short audio samples, sound effects, and production elements using text prompts.
Log in to HuggingFace and navigate to the model landing page:
https://huggingface.co/stabilityai/stable-audio-open-small/tree/main
You may need to fill out a form with your contact information to use the model:
Download and copy the configuration file model_config.json and the model itself, model.ckpt, to your workspace directory, and verify they exist by running the command:
ls -lha $WORKSPACE/model_config.json $WORKSPACE/model.ckpt
You can learn more about stable-audio-open-small on Hugging Face .
A good prompt for the Stable Audio Open Small model can include the following elements:
The order of prompt parameters matters. For more information, see the Prompt structure user guide .
You can explore training and inference code for audio generation models in the Stable Audio Tools repository .
Now that you’ve downloaded the model, you’re ready to convert it to LiteRT format in the next step.
