Use a coding agent to implement and validate an adapter
Use this advanced workflow only when the model doesn’t match either validated adapter included with Image Analysis: MobileSAM or Depth Anything V2. A different model might need another runtime dependency, tensor mapping, and preprocessing pipeline. It might also need a different prompt control, output decoder, or result visualization.
The included LiteRT and ONNX adapter files are implementation stubs. They show where runtime-specific code belongs, but they aren’t ready-made alternatives that can execute an arbitrary .tflite or .onnx model.
Note
Use an advanced coding agent that supports long-context, multi-file editing, image-model reasoning, and terminal tools. The agent needs to be able to trace Kotlin interfaces and determine tensor and preprocessing contracts from evidence. It also needs to update Gradle dependencies and interpret Android build errors. Lightweight autocomplete or chat-only tools are unlikely to complete this workflow reliably.
Treat generated code as a starting point that needs developer review and device validation.
Check the project and tools
Return to the cloned application directory and check the files and tools used by the workflow:
cd "$HOME/image-to-image-android/ai-portal-android-app-image-to-image"
test -f scripts/inspect_android_model.py
test -x gradlew
java -version
adb get-state
.hf-venv/bin/python -c \
    'import huggingface_hub; print(huggingface_hub.__version__)'
$IMAGE_MODEL_WORKSPACE = Join-Path $env:USERPROFILE "image-to-image-android"
Set-Location (Join-Path $IMAGE_MODEL_WORKSPACE "ai-portal-android-app-image-to-image")
Test-Path scripts\inspect_android_model.py
Test-Path gradlew.bat
java -version
adb get-state
.\.hf-venv\Scripts\python.exe -c `
    "import huggingface_hub; print(huggingface_hub.__version__)"
Both Windows path checks should return True. The other commands identify the Java version, connected device, and huggingface_hub version.
Download and inspect the model package
Run the following commands to download and inspect the model package:
printf 'Arm model repository ID: '
read -r MODEL_SOURCE
printf 'Runtime: '
read -r MODEL_RUNTIME
printf 'Workload: '
read -r MODEL_WORKLOAD
export MODEL_ID="${MODEL_SOURCE##*/}"
export MODEL_DIR="model/custom-$MODEL_ID"
.hf-venv/bin/hf download "$MODEL_SOURCE" --local-dir "$MODEL_DIR"
.hf-venv/bin/python scripts/inspect_android_model.py \
    --model-id "$MODEL_ID" \
    --model-source "https://huggingface.co/$MODEL_SOURCE" \
    --runtime "$MODEL_RUNTIME" \
    --workload "$MODEL_WORKLOAD" \
    --local-model-dir "$MODEL_DIR"
$MODEL_SOURCE = Read-Host "Arm model repository ID"
$MODEL_RUNTIME = Read-Host "Runtime"
$MODEL_WORKLOAD = Read-Host "Workload"
$MODEL_ID = Split-Path -Leaf $MODEL_SOURCE
$MODEL_DIR = Join-Path "model" "custom-$MODEL_ID"
.\.hf-venv\Scripts\hf.exe download $MODEL_SOURCE --local-dir $MODEL_DIR
.\.hf-venv\Scripts\python.exe scripts\inspect_android_model.py `
    --model-id $MODEL_ID `
    --model-source "https://huggingface.co/$MODEL_SOURCE" `
    --runtime $MODEL_RUNTIME `
    --workload $MODEL_WORKLOAD `
    --local-model-dir $MODEL_DIR
Enter the complete Arm Hugging Face repository ID, runtime, and workload when prompted. Use executorch, litert, or onnxruntime for the runtime. Use image-segmentation or image-to-image for the workload.
The script creates android_model_config.json, model-context/model-summary.json, and copied metadata under model-context/metadata/. Review the summary and confirm that it identifies the intended Android artifact and its supporting files. If the summary lists several candidates, identify the correct artifact from the model card before continuing.
Give the coding agent local evidence
Open the coding agent in the application project and ask it to:
  1. Read android_model_config.json, model-context/model-summary.json, copied metadata, and the model card.
  2. Read model_catalog.json and the closest model adapter.
  3. Read RuntimeRunner.kt, RuntimeRunnerFactory.kt, ImageLoader.kt, and MainActivity.kt.
  4. State the documented model inputs and outputs, preprocessing, runtime dependency, Android requirements, and artifact layout before editing code.
  5. Update one catalog entry and implement only the model-specific adapter and factory wiring selected by the runtime.
  6. Add a pinned official Android runtime dependency.
  7. Report any required AAR or native library instead of inventing its package name or location.
  8. Validate every required file under filesDir/models/<model-id>/, and keep resolved paths inside that directory.
  9. Implement the documented image resizing, color conversion, normalization, and prompt encoding.
  10. Implement the documented tensor order, runtime call, output decoding, and result rendering.
  11. Update the UI only when the new model needs different input controls or an output other than a segmentation mask.
  12. Build and lint the debug APK, then report the exact model files to copy to the phone and any facts that remain unresolved.
The agent must not embed access tokens, download models from the Android application, or silently change runtimes. It must not infer tensor order from names alone, or claim success while a dependency or model contract is unknown.
Review and validate the result
Review every generated source and build-file change. After review, build the application:
./gradlew :app:assembleDebug :app:lintDebug
.\gradlew.bat :app:assembleDebug :app:lintDebug
Copy the exact files reported by the agent into the catalog’s application-private model directory. Test representative images against a documented reference implementation or known-good result. A successful build proves that the source compiles. However, it doesn’t prove that preprocessing, tensor mapping, or output decoding is correct.
What you’ve accomplished
You’ve inspected another Arm AI Portal image model, supplied a coding agent with local model evidence, and identified the build and device checks needed to validate its adapter.
You can use this workflow to implement and validate an adapter for an Arm AI Portal image model that Image Analysis doesn’t yet support.
