Download the validated model
You’ll use the validated MobileSAM ExecuTorch path. Image Analysis also includes a Depth Anything V2 adapter, covered in Run Depth Anything V2 depth estimation on Android . The application already contains the MobileSAM catalog entry, adapter, preprocessing, and mask rendering.
Run the download from the cloned application directory:
export MODEL_ID="mobile-sam-int8-xnnpack-executorch"
export MODEL_FILE="mobile_sam_raspberry_executorch_optimized.pte"
export MODEL_DIR="model/$MODEL_ID"
.hf-venv/bin/hf download "Arm/$MODEL_ID" "$MODEL_FILE" \
    --local-dir "$MODEL_DIR"
test -f "$MODEL_DIR/$MODEL_FILE"
$MODEL_ID = "mobile-sam-int8-xnnpack-executorch"
$MODEL_FILE = "mobile_sam_raspberry_executorch_optimized.pte"
$MODEL_DIR = "model\$MODEL_ID"
.\.hf-venv\Scripts\hf.exe download "Arm/$MODEL_ID" $MODEL_FILE `
    --local-dir $MODEL_DIR
Test-Path "$MODEL_DIR\$MODEL_FILE"
The final check returns no output on macOS or Linux when the file exists. On Windows, it returns True.
The .pte file is a pre-exported model program and its parameters. The file isn’t an Android executable. The application APK already contains ExecuTorch 1.3.1 and its native runtime libraries, which load and execute this model program.
Copy the model to application-private storage
The catalog tells the application to load the model from filesDir/models/mobile-sam-int8-xnnpack-executorch/. Stage the downloaded file under /data/local/tmp, then use run-as to copy it into the debuggable application’s private directory:
export ANDROID_PACKAGE="com.arm.learningpath.imagetoimage"
adb push "$MODEL_DIR/$MODEL_FILE" "/data/local/tmp/$MODEL_FILE"
adb shell "run-as $ANDROID_PACKAGE mkdir -p files/models/$MODEL_ID"
adb shell "run-as $ANDROID_PACKAGE cp /data/local/tmp/$MODEL_FILE files/models/$MODEL_ID/$MODEL_FILE"
adb shell "run-as $ANDROID_PACKAGE ls -l files/models/$MODEL_ID/$MODEL_FILE"
adb shell rm "/data/local/tmp/$MODEL_FILE"
$ANDROID_PACKAGE = "com.arm.learningpath.imagetoimage"
adb push "$MODEL_DIR\$MODEL_FILE" "/data/local/tmp/$MODEL_FILE"
The ls command displays the copied file and its size. The final adb shell rm command removes only the temporary device copy. The downloaded source file remains under model/ on your development computer. The model directory must match the id in app/src/main/assets/model_catalog.json.
Generate a segmentation mask
Start the application:
adb shell am start -n com.arm.learningpath.imagetoimage/.ui.MainActivity
For the first run, choose a JPEG or PNG image with one distinct object near the center. Then:
  1. Confirm that MobileSAM INT8 Segmentation is selected.
  2. Select Load model.
  3. Select Choose image and choose the image from the phone.
  4. Confirm that the dashed prompt box covers the object that you want to segment.
  5. Select Run segmentation.
The fixed box covers the center 80 percent of the image after it’s resized to 1024 x 1024. Keeping the prompt fixed makes the first run repeatable. This example doesn’t include controls for moving or resizing the box.
The result should show a translucent cyan mask over an object within the box. The result panel reports the following:
  • Selected mask
  • Predicted intersection over union (IoU)
  • Mask coverage
  • Mask logit range
  • Model load time
  • Run time
After you copy the model into application-private storage, segmentation runs locally on the phone and doesn’t need a network connection.
Understand what the adapter validates
model_catalog.json selects MobileSamExecuTorchAdapter through the mobile-sam-executorch adapter ID. The adapter isolates MobileSAM’s model-specific contract from the shared Android screen.
When you select Load model, the adapter checks that the configured .pte file exists inside the application-private model directory. The adapter loads the program, confirms that it exposes a forward method, and checks that the method declares the XNNPACK backend.
When you select Run segmentation, the application corrects the image orientation, resizes the image, and creates the image and box-prompt tensors. After ExecuTorch runs forward, the postprocessor checks for two float32 outputs with shapes [1, 3, 256, 256] and [1, 3]. The postprocessor then selects the mask with the highest predicted IoU and renders the cyan overlay.
These checks confirm that the artifact matches the supplied adapter. They don’t measure segmentation accuracy or guarantee that every operation uses the same optimized kernel on every phone.
Validate segmentation results
Run a second image with a distinct central object and confirm that the mask changes with the input. Generated masks don’t have a fixed textual output, so check that the overlay follows a plausible object boundary. Also ensure that the result panel contains finite IoU, coverage, and logit values.
Treat the timing as illustrative rather than a benchmark.
You’ve now downloaded the validated MobileSAM program and copied it into application-private storage. You’ve generated and checked segmentation masks, and traced the adapter’s compatibility checks and output rendering.
Next, you’ll learn how to extend Image Analysis to use an Arm AI Portal model without an included validated adapter.
