Connect an Android phone
Enable Developer options and USB debugging on the phone. Connect the phone with a data-capable USB cable, unlock it, and accept the debugging authorization prompt.
Verify the connection:
adb devices -l
The output lists the authorized phone and its device serial. If the output reports unauthorized, unlock the phone and accept the debugging prompt. Windows might also need the phone manufacturer’s USB driver. If the phone doesn’t appear, see Run apps on a hardware device .
Prepare the application and model downloader
Clone Image Analysis, then create the Python environment used to download MobileSAM:
mkdir -p "$HOME/image-to-image-android"
cd "$HOME/image-to-image-android"
git clone https://github.com/arm-education/ai-portal-android-app-image-to-image.git
cd ai-portal-android-app-image-to-image
python3 -m venv .hf-venv
.hf-venv/bin/python -m pip install --upgrade pip huggingface_hub
.hf-venv/bin/hf auth login
.hf-venv/bin/hf auth whoami
$IMAGE_MODEL_WORKSPACE = Join-Path $env:USERPROFILE "image-to-image-android"
New-Item -ItemType Directory -Force -Path $IMAGE_MODEL_WORKSPACE | Out-Null
Set-Location $IMAGE_MODEL_WORKSPACE
Set-Location ai-portal-android-app-image-to-image
python -m venv .hf-venv
.\.hf-venv\Scripts\python.exe -m pip install --upgrade pip huggingface_hub
.\.hf-venv\Scripts\hf.exe auth login
.\.hf-venv\Scripts\hf.exe auth whoami
Sign in with an account that has access to the Arm model repository and use a read token when prompted.
Build and install the application
Before building, confirm the Gradle JVM configuration:
chmod +x gradlew
./gradlew --version
.\gradlew.bat --version
The Launcher JVM entry should report JDK 17 or later. The Daemon JVM entry should report that Java 17 is configured by gradle/gradle-daemon-jvm.properties. Gradle downloads a compatible JDK 17 automatically when one isn’t already available.
Build the debug APK, then run the unit tests and lint checks:
./gradlew :app:testDebugUnitTest :app:assembleDebug :app:lintDebug
.\gradlew.bat :app:testDebugUnitTest :app:assembleDebug :app:lintDebug
After Gradle reports BUILD SUCCESSFUL, install the APK and start Image Analysis:
adb install -r app/build/outputs/apk/debug/app-debug.apk
adb shell am start -n com.arm.learningpath.imagetoimage/.ui.MainActivity
adb install -r app\build\outputs\apk\debug\app-debug.apk
Image Analysis opens with MobileSAM selected by default. The model menu also contains Depth Anything V2 Small INT8, which is covered in Run Depth Anything V2 depth estimation on Android . The MobileSAM status reports (placeholder bundled) because you haven’t copied the real Hugging Face model into application-private storage yet.
You’ve connected an Arm-based Android phone, prepared the application and model downloader, and installed the debug APK.
Next, you’ll run the MobileSAM model on the phone.
