Arm AI Portal
The Arm AI Portal provides a catalog of AI models across different runtimes, use cases, optimization profiles, and Arm-based targets. It includes benchmarking and compatibility information, code examples, and deployment guidance.
You’ll use an Android application called Image Analysis to run MobileSAM, an image-segmentation model from the Arm AI Portal, on a physical Arm-based Android phone. MobileSAM receives an image and a box prompt, then returns masks that identify an object inside the box.
Image Analysis includes validated ExecuTorch adapters for MobileSAM and Depth Anything V2. You’ll use the MobileSAM adapter, which does the following:
  • Validates the model package
  • Prepares the image and prompt tensors
  • Calls the runtime
  • Decodes the output masks
  • Converts the selected mask into a visual overlay
Check the host development tools
You’ll use a terminal and a physical Arm-based Android phone. First, you’ll build the application with the Gradle wrapper, then use Android Debug Bridge (adb) to install and start it on the phone.
Open a terminal. On Windows, use PowerShell.
Check the installed tools:
git --version
java -version
javac -version
python3 --version
python3 -m pip --version
curl --version
unzip -v
git --version
java -version
javac -version
python --version
python -m pip --version
$PSVersionTable.PSVersion
Install any missing tools before continuing. Ensure the Java compiler version is 17 or later. Image Analysis configures Gradle to provision its JDK 17 build toolchain automatically during the first build.
Note
You can open the cloned project in Android Studio and run it on a connected phone or an Android Virtual Device (AVD). For an AVD, select a recent system image compatible with the application’s arm64-v8a native libraries. An emulator is useful for functional testing, but its performance and memory behavior aren’t representative of a physical Arm-based phone.
Install the Android command-line tools
The following commands download Google’s Android SDK Command-Line Tools , verify the pinned archive checksum, and place the tools under ANDROID_HOME:
if [ -z "${ANDROID_HOME:-}" ]; then
    case "$(uname -s)" in
        Darwin) export ANDROID_HOME="$HOME/Library/Android/sdk" ;;
        Linux) export ANDROID_HOME="$HOME/Android/Sdk" ;;
        *) printf 'Unsupported operating system.\n' >&2; false ;;
    esac
fi
case "$(uname -s)-$(uname -m)" in
    Darwin-arm64)
        android_cli_archive="commandlinetools-mac_arm64-15859902_latest.zip"
        android_cli_sha256="835b62a26162b229b441d1f6d4680383815a270809eb33522c0d480fa5002c4e"
    Darwin-x86_64)
        android_cli_archive="commandlinetools-mac_x86_64-15859902_latest.zip"
        android_cli_sha256="c5a6378ab5cf7e0d5701921405115befff13e9ff7417fb588389338f8bd050f3"
    Linux-*)
        android_cli_archive="commandlinetools-linux-15859902_latest.zip"
        android_cli_sha256="4e4c464f145a7512b57d088ac6c278c03c9eea610886b35a5e0804e74eedf583"
    *) printf 'No Android command-line archive is configured for this computer.\n' >&2; false ;;
esac
android_cli_temp="$(mktemp -d)"
curl --fail --location \
    "https://dl.google.com/android/repository/$android_cli_archive" \
    --output "$android_cli_temp/$android_cli_archive"
if command -v sha256sum >/dev/null 2>&1; then
    printf '%s  %s\n' "$android_cli_sha256" "$android_cli_temp/$android_cli_archive" |
        sha256sum --check
else
        shasum -a 256 -c
fi
unzip -q "$android_cli_temp/$android_cli_archive" -d "$android_cli_temp"
mkdir -p "$ANDROID_HOME/cmdline-tools/latest"
cp -R "$android_cli_temp/cmdline-tools/." "$ANDROID_HOME/cmdline-tools/latest/"
export PATH="$ANDROID_HOME/cmdline-tools/latest/bin:$ANDROID_HOME/platform-tools:$PATH"
if (-not $env:ANDROID_HOME) {
    $env:ANDROID_HOME = "$env:LOCALAPPDATA\Android\Sdk"
$androidCliArchive = "commandlinetools-win-15859902_latest.zip"
$androidCliSha256 = "90ae805d20434428bffcb699c290860f19bb5f66a67e6b330067e3de801fb04a"
$androidCliTemp = Join-Path $env:TEMP "android-cli-$([guid]::NewGuid())"
$androidCliZip = Join-Path $androidCliTemp $androidCliArchive
New-Item -ItemType Directory -Path $androidCliTemp | Out-Null
Invoke-WebRequest `
    -Uri "https://dl.google.com/android/repository/$androidCliArchive" `
    -OutFile $androidCliZip
$downloadedSha256 = (Get-FileHash $androidCliZip -Algorithm SHA256).Hash
if ($downloadedSha256 -ne $androidCliSha256) {
    throw "Android command-line tools checksum verification failed."
Expand-Archive -Path $androidCliZip -DestinationPath $androidCliTemp
$latestTools = Join-Path $env:ANDROID_HOME "cmdline-tools\latest"
New-Item -ItemType Directory -Force -Path $latestTools | Out-Null
Copy-Item -Path "$androidCliTemp\cmdline-tools\*" `
    -Destination $latestTools -Recurse -Force
$env:Path = "$latestTools\bin;$env:ANDROID_HOME\platform-tools;$env:Path"
If you already have an SDK in ANDROID_HOME, the commands reuse that location.
Continue in the same terminal so that the environment variables remain set.
Install the required SDK packages
Review and accept the Android SDK licenses when prompted. After accepting licenses, install and verify the required packages:
sdkmanager --sdk_root="$ANDROID_HOME" --licenses
sdkmanager --sdk_root="$ANDROID_HOME" \
    "platform-tools" \
    "platforms;android-35" \
    "build-tools;35.0.0"
sdkmanager --version
adb version
test -d "$ANDROID_HOME/platforms/android-35"
test -d "$ANDROID_HOME/build-tools/35.0.0"
sdkmanager.bat "--sdk_root=$env:ANDROID_HOME" --licenses
sdkmanager.bat "--sdk_root=$env:ANDROID_HOME" `
    "platform-tools" `
    "platforms;android-35" `
sdkmanager.bat --version
adb version
Test-Path "$env:ANDROID_HOME\platforms\android-35"
Test-Path "$env:ANDROID_HOME\build-tools\35.0.0"
You’ve installed and verified the Android command-line tools needed to build and deploy the application.
Next, you’ll build and install the application on your Android phone.
