Arm AI Portal
The Arm AI Portal provides a catalog of AI models across different runtimes, use cases, optimization profiles, and Arm-based targets. It includes benchmarking and compatibility information, code examples, and deployment guidance.
You’ll use an application called Image Analysis to run Depth Anything V2 Small on a physical Arm-based Android phone. Depth Anything V2 Small is a monocular depth-estimation model from the Arm AI Portal.
The application includes a validated ExecuTorch adapter. The adapter prepares the image, runs the model, validates its relative-disparity output, and renders a grayscale depth map.
Check the existing development tools
Image Analysis builds with Android SDK 35 and Java 17. Before installing anything, list the versions that are already available on your development computer:
git --version
java -version
javac -version
python3 --version
python3 -m pip --version
brew --version
git --version
java -version
javac -version
python3 --version
curl --version
git --version
java -version
javac -version
py --version
py -m pip --version
$PSVersionTable.PSVersion
winget --version
A command not found or is not recognized message identifies a host tool that you need to install.
Install any missing host prerequisites before continuing, then rerun the version checks. Ensure that java and javac report version 17 or later. The application configures Gradle to provision its JDK 17 build toolchain automatically during the first build.
Install Android CLI
Install Android CLI for your development computer:
brew tap android/tap
brew install android-cli
curl -fsSL https://dl.google.com/android/cli/latest/linux_x86_64/install.sh |
    bash
winget install --exact --id Google.AndroidCLI
Close and reopen the terminal after installation if the android command isn’t immediately available. Then, update Android CLI and confirm its version:
android update
android -V
Install the Android SDK packages
Set the SDK location, add platform-tools to PATH, and install the packages:
export ANDROID_HOME="$HOME/Library/Android/sdk"
export PATH="$ANDROID_HOME/platform-tools:$PATH"
android --sdk="$ANDROID_HOME" sdk install \
    platform-tools \
    platforms/android-35 \
    build-tools/35.0.0
export ANDROID_HOME="$HOME/Android/Sdk"
    platform-tools \
    build-tools/35.0.0
$env:ANDROID_HOME = "$env:LOCALAPPDATA\Android\Sdk"
$env:Path = "$env:ANDROID_HOME\platform-tools;$env:Path"
android "--sdk=$env:ANDROID_HOME" sdk install `
    platform-tools `
    platforms/android-35 `
    build-tools/35.0.0
Review and accept the Android SDK licenses when prompted.
Verify Android CLI, adb, Android SDK Platform 35, and Android SDK Build Tools 35.0.0:
android -V
android --sdk="$ANDROID_HOME" sdk list \
    'platform-tools|platforms/android-35|build-tools/35.0.0'
adb version
test -d "$ANDROID_HOME/platforms/android-35"
test -d "$ANDROID_HOME/build-tools/35.0.0"
android -V
android "--sdk=$env:ANDROID_HOME" sdk list `
adb version
Test-Path "$env:ANDROID_HOME\platforms\android-35"
Test-Path "$env:ANDROID_HOME\build-tools\35.0.0"
The final two checks have no output on macOS or Linux when the directories exist. Both checks return True on Windows.
You’ve verified the host tools and prepared Android CLI, Platform Tools, Android SDK Platform 35, and Android SDK Build Tools 35.0.0.
Next, you’ll connect an Arm-based Android phone, then build and install Image Analysis.
