Your application might contain execution nodes which produce resources (outputs) that are unused. Here is an excerpt from our sample trace which shows the problem:
Figure 1. A render pass creating an unused renderbuffer (highlighted)
This excerpt shows a render pass (RP0) which writes three output resources to memory. These are a color image, texture 1 (T1), and the two aspects of a packed depth and stencil image, renderbuffer 1 (RB1.d and RB.s).
The texture is fed into another execution node, Tr2. This is a transfer node, number 2. From here, the data ultimately makes its way into the swapchain – and is therefore seen by the user.
The renderbuffer nodes RB1.d and RB1.s are different. They are not sent to another execution node, they are unused.
This wastes both bandwidth and power.
Remove any API calls from your application which generate outputs which are unused. You can find the relevant API calls by:
