Finding GPU-heavy parts of your application
Your first step is to identify which parts of your application are limited by GPU performance.
Streamline Performance Analyzer is a good place to start, it is included in Arm Performance Studio.
Setting up Streamline
Before starting a capture in Streamline, you’ll need to ask it to gather GPU data. This is done in the Configure Capture section of the Start view.
If you have an Arm GPU, basic configuration is simple:
  • Deselect the “Use advanced mode” checkbox.
  • Select the “Capture Arm GPU” checkbox.
If you have some other GPU, or want more control over the data collected, you’ll need to select GPU counters manually:
  • Select the “Use advanced mode” checkbox.
  • Click the “Select counters” button to open the Counters window.
  • Inside the Counters window, select the counters you wish to analyze. Reference Guides are available for Arm GPUs .
  • Close the Counters window.
For more details, refer to the Get Started with Streamline tutorial, or Starting a capture in the Arm Streamline User Guide.
Capturing GPU data in Streamline
Once you have chosen GPU counters, click the “Start capture” button to begin your capture.
Streamline will produce a graph showing the most GPU-heavy parts of your application. Refer to the Timeline overview in the Arm Streamline User Guide.
Capturing a render graph
Now that you have identified areas of your application that you want to optimize, you can turn from Streamline to Frame Advisor.
Ask Frame Advisor to capture data relating to the problem areas you have observed:
  • Click “Capture new trace” in Frame Advisor’s launch screen
  • Connect to your application
  • In the Capture screen, select the number of frames you wish to capture
  • When you’ve reached the GPU-heavy part of the application run, click “Capture”, then “Analyze” to advance to the Analysis screen
Viewing the render graph
Observe that part of the Frame Advisor window is labeled “Render Graph”. This contains the render graph relating to the frames you asked Frame Advisor to analyze.
Assume that you’ve captured the following render graph:
Image Alt Text:An inefficient render graph in need of optimizationAn inefficient render graph in need of optimization
In the next section, you will use this graph to understand some common application faults.
