Run the PTQ example and check
./output/ for an exported .vgf artifact. Open the artifact in Model Explorer with the VGF adapter and inspect the graph.Find the PTQ export in
./output/ and the QAT export in ./output_qat/. Open the exported .vgf files from those directories for inspection.PTQ optimizes for speed of iteration, while QAT optimizes for quality and robustness. Export both, inspect the graphs in Model Explorer, and compare outputs to choose a strategy that fits your accuracy and development needs.
First, run the CIFAR-10 example to verify your environment. Then, adapt the PTQ or QAT export structure in
quantize_and_export_vgf.py for your FP32 model, inference input, and representative calibration data or QAT fine-tuning loop.Check for unexpected layout conversions, operators that you didn’t intend to run on your GPU path, and model I/O shapes that don’t match your integration. Use these findings before you integrate the
.vgf artifact into your runtime.
