In this section, you run quantization-aware training (QAT) so the model learns to be robust to quantization effects.
The default workflow is to extend the runnable CIFAR-10 based example from the PTQ step so you can compare PTQ and QAT outputs using the same model and data.
In quantize_and_export_vgf.py, update your TorchAO imports to include the QAT helpers:
from torchao.quantization.pt2e.quantize_pt2e import (
convert_pt2e,
prepare_qat_pt2e,
from torchao.quantization.pt2e import (
move_exported_model_to_eval,
move_exported_model_to_train,
Then add the QAT training function and example entry point. This code prepares the exported model for QAT, fine-tunes for a small number of epochs, converts to INT8, and exports to .vgf.
def train_model_qat(
model: nn.Module,
train_loader: DataLoader,
test_loader: DataLoader | None = None,
device: str = "cpu",
epochs: int = 1,
lr: float = 1e-4,
log_every: int = 50,
model.to(device)
optimizer = torch.optim.AdamW(model.parameters(), lr=lr)
for epoch in range(epochs):
move_exported_model_to_train(model)
for step, (x_hr, _y) in enumerate(train_loader):
x_hr = x_hr.to(device)
x_lr = make_lowres_input(x_hr)
optimizer.zero_grad()
pred = model(x_lr)
loss = F.mse_loss(pred, x_hr)
loss.backward()
optimizer.step()
if log_every and (step % log_every == 0):
print(f"qat epoch={epoch+1} step={step} loss={loss.item():.6f}")
if test_loader is not None:
move_exported_model_to_eval(model)
psnr = evaluate_psnr(model, test_loader, device=device, max_batches=50)
print(f"qat epoch={epoch+1} end psnr={psnr:.2f} dB")
return model
def qat_example(device="cpu"):
"""QAT example: prepare for QAT, fine-tune, convert, then export to VGF."""
# 1) Train (or load) a baseline FP32 model.
model = SmallUpscalerModel()
train_loader, test_loader = get_data_loaders()
model = train_model(model, train_loader, test_loader, device=device, epochs=1)
# 2) Export the FP32 model.
example_input = make_example_input_from_loader(train_loader, batch_size=1)
exported_model = torch.export.export(model, example_input, strict=True).module(check_guards=False)
# 3) Configure the Arm backend quantizer.
tosa_spec = "TOSA-1.00+INT"
quantizer = TOSAQuantizer(TosaSpecification.create_from_string(tosa_spec))
quantizer.set_global(get_symmetric_quantization_config(is_qat=True))
# 4) Prepare for QAT.
qat_ready_model = prepare_qat_pt2e(exported_model, quantizer)
# 5) Fine-tune with fake-quant enabled.
qat_ready_model = train_model_qat(
qat_ready_model,
train_loader,
test_loader,
device=device,
epochs=1,
lr=1e-4,
# 6) Convert to an INT8 model.
qat_ready_model = qat_ready_model.to("cpu")
move_exported_model_to_eval(qat_ready_model)
qat_int8_model = convert_pt2e(qat_ready_model)
# 7) Export again so the quantized graph is captured.
aten_dialect = torch.export.export(
qat_int8_model,
args=example_input,
strict=True,
# 8) Partition and dump a `.vgf` artifact.
compile_spec = VgfCompileSpec(TosaSpecification.create_from_string(tosa_spec))
vgf_partitioner = VgfPartitioner(
compile_spec.dump_intermediate_artifacts_to("./output_qat/")
to_edge_transform_and_lower(aten_dialect, partitioner=[vgf_partitioner])
Update __main__ to call qat_example() and run the script:
python quantize_and_export_vgf.py
If export fails with a missing model converter error, you likely forgot to source the Arm backend setup_path.sh in your current terminal session.
As the script runs, you should see QAT training logs (prefixed with qat). When export completes, you should see .vgf output under ./output_qat/.
If PTQ degrades model accuracy too much, QAT is the next step. The workflow is the same as PTQ, but you insert a short fine-tuning phase after you prepare the model for QAT.
In practice, you already have a training loop for your upscaler. The simplest way to use QAT is to reuse that loop and point it at the QAT-prepared exported model.
Use the following minimal structure as a starting point for your own project. You supply:
model_fp32: your baseline FP32 modelexample_input: a tuple of input tensorsfine_tune_qat: a function that runs your fine-tuning loop (one or more epochs)
import torch
from executorch.backends.arm.tosa.specification import TosaSpecification
from executorch.backends.arm.vgf.compile_spec import VgfCompileSpec
from executorch.backends.arm.vgf.partitioner import VgfPartitioner
from executorch.backends.arm.quantizer.arm_quantizer import (
get_symmetric_quantization_config,
TOSAQuantizer,
from executorch.exir import to_edge_transform_and_lower
from torchao.quantization.pt2e.quantize_pt2e import convert_pt2e, prepare_qat_pt2e
from torchao.quantization.pt2e import move_exported_model_to_eval
def export_vgf_int8_qat(
model_fp32: torch.nn.Module,
example_input: tuple[torch.Tensor, ...],
fine_tune_qat,
output_dir: str,
tosa_spec: str = "TOSA-1.00+INT",
model_fp32 = model_fp32.to("cpu")
model_fp32.eval()
exported = torch.export.export(model_fp32, example_input, strict=True).module(check_guards=False)
qat_ready = prepare_qat_pt2e(exported, quantizer)
# Run your fine-tuning loop here. This is where QAT earns its keep.
fine_tune_qat(qat_ready)
qat_ready = qat_ready.to("cpu")
move_exported_model_to_eval(qat_ready)
q = convert_pt2e(qat_ready)
aten_dialect = torch.export.export(q, args=example_input, strict=True)
vgf_partitioner = VgfPartitioner(compile_spec.dump_intermediate_artifacts_to(output_dir))
In this section, you:
.vgf artifact using the ExecuTorch Arm backendIn the next section, you inspect both exported graphs in Model Explorer to validate the output before runtime integration.
