In this section, you apply post-training quantization (PTQ) to an image-to-image model and export a .vgf artifact.
The default workflow in this Learning Path is end to end: you run a complete CIFAR-10-based example, generate a .vgf artifact, and validate that the Arm backend export path works on your machine.
After that, you take the same PTQ export logic and apply it to your own model and calibration data.
Create a file called quantize_and_export_vgf.py and add the following code.
This example uses CIFAR-10 as a convenient image source. It constructs a low-resolution input by downsampling an image, then trains the model to reconstruct the original image. This is a practical proxy for a real neural upscaler.
import torch
from torch.utils.data import DataLoader
from torch import nn
from torchvision import datasets, transforms
import torch.nn.functional as F
from executorch.backends.arm.tosa.specification import TosaSpecification
from executorch.backends.arm.vgf.compile_spec import VgfCompileSpec
from executorch.backends.arm.vgf.partitioner import VgfPartitioner
from executorch.backends.arm.quantizer.arm_quantizer import (
get_symmetric_quantization_config,
TOSAQuantizer,
from executorch.exir import to_edge_transform_and_lower
from torchao.quantization.pt2e.quantize_pt2e import (
convert_pt2e,
prepare_pt2e,
class SmallUpscalerModel(nn.Module):
"""Small image-to-image model for upscaling workflows."""
def __init__(self):
super().__init__()
self.net = nn.Sequential(
nn.Conv2d(3, 32, kernel_size=3, padding=1),
nn.ReLU(),
nn.Conv2d(32, 32, kernel_size=3, padding=1),
nn.ReLU(),
nn.Conv2d(32, 3, kernel_size=3, padding=1),
def forward(self, x_lowres):
# Upscale input first, then refine.
x = F.interpolate(x_lowres, scale_factor=2.0, mode="bilinear", align_corners=False)
x = self.net(x)
return x
def get_data_loaders(root="./data", batch_size=64):
tfm = transforms.Compose([
transforms.ToTensor(),
train_ds = datasets.CIFAR10(root=root, train=True, download=True, transform=tfm)
test_ds = datasets.CIFAR10(root=root, train=False, download=True, transform=tfm)
train_loader = DataLoader(train_ds, batch_size=batch_size, shuffle=True, drop_last=True)
test_loader = DataLoader(test_ds, batch_size=batch_size, shuffle=False)
return train_loader, test_loader
def make_lowres_input(x_hr: torch.Tensor):
# Simulate a game render at lower resolution.
return F.interpolate(x_hr, scale_factor=0.5, mode="bilinear", align_corners=False)
@torch.no_grad()
def evaluate_psnr(model, loader, device="cpu", max_batches=50):
psnr_sum = 0.0
count = 0
for i, (x_hr, _y) in enumerate(loader):
if max_batches is not None and i >= max_batches:
break
x_hr = x_hr.to(device)
x_lr = make_lowres_input(x_hr)
pred = model(x_lr)
mse = F.mse_loss(pred, x_hr)
psnr = 10.0 * torch.log10(1.0 / mse.clamp_min(1e-12))
psnr_sum += psnr.item()
count += 1
return psnr_sum / max(1, count)
def train_model(
model: nn.Module,
train_loader: DataLoader,
test_loader: DataLoader | None = None,
device: str = "cpu",
epochs: int = 1,
lr: float = 1e-3,
log_every: int = 50,
model.to(device)
optimizer = torch.optim.AdamW(model.parameters(), lr=lr)
for epoch in range(epochs):
model.train()
for step, (x_hr, _y) in enumerate(train_loader):
optimizer.zero_grad()
pred = model(x_lr)
loss = F.mse_loss(pred, x_hr)
loss.backward()
optimizer.step()
if log_every and (step % log_every == 0):
print(f"epoch={epoch+1} step={step} loss={loss.item():.6f}")
if test_loader is not None:
model.eval()
psnr = evaluate_psnr(model, test_loader, device=device, max_batches=50)
print(f"epoch={epoch+1} end psnr={psnr:.2f} dB")
model.train()
return model
def make_example_input_from_loader(loader, batch_size=1):
x_hr, _y = next(iter(loader))
# Use channels_last to reduce transpose noise in the exported graph.
x_hr = x_hr[:batch_size].to("cpu").to(memory_format=torch.channels_last)
return (x_lr,)
def make_calibration_batches(loader: DataLoader, num_batches: int):
cal = []
if i >= num_batches:
break
x_lr = make_lowres_input(x_hr.to("cpu"))
cal.append(x_lr)
if len(cal) == 0:
raise RuntimeError("Calibration set is empty; check loader/num_batches.")
return cal
def ptq_example(device="cpu"):
"""PTQ example: calibrate, convert, then export to VGF."""
# 1) Train (or load) a baseline model.
model = SmallUpscalerModel()
train_loader, test_loader = get_data_loaders()
# Keep training short for the tutorial.
model = train_model(model, train_loader, test_loader, device=device, epochs=1)
model = model.to("cpu")
model.eval()
# 2) Export the FP32 model.
example_input = make_example_input_from_loader(train_loader, batch_size=1)
exported_model = torch.export.export(model, example_input, strict=True).module(check_guards=False)
# 3) Configure the Arm backend quantizer.
tosa_spec = "TOSA-1.00+INT"
quantizer = TOSAQuantizer(TosaSpecification.create_from_string(tosa_spec))
quantizer.set_global(get_symmetric_quantization_config(is_qat=False))
# 4) Prepare for PTQ.
quantized_export_model = prepare_pt2e(exported_model, quantizer)
# 5) Calibrate with representative inputs.
calibration_loader, _ = get_data_loaders(batch_size=1)
calibration_data = make_calibration_batches(calibration_loader, num_batches=500)
with torch.no_grad():
for x_lr in calibration_data:
quantized_export_model(x_lr)
# 6) Convert to an INT8 model.
quantized_export_model = convert_pt2e(quantized_export_model)
# 7) Export again so the quantized graph is captured.
aten_dialect = torch.export.export(
quantized_export_model,
args=example_input,
strict=True,
# 8) Partition and dump a `.vgf` artifact.
compile_spec = VgfCompileSpec(TosaSpecification.create_from_string(tosa_spec))
vgf_partitioner = VgfPartitioner(
compile_spec.dump_intermediate_artifacts_to("./output/")
to_edge_transform_and_lower(aten_dialect, partitioner=[vgf_partitioner])
if __name__ == "__main__":
Run the script:
python quantize_and_export_vgf.py
The output is similar to:
epoch=1 step=0 loss=0.208134
epoch=1 step=50 loss=0.053812
epoch=1 end psnr=19.42 dB
Check the ./output/ directory for exported files. The exact filenames depend on your ExecuTorch version and backend configuration, but the directory should include an exported .vgf artifact.
If export fails because of bilinear resize, switch the interpolation modes in make_lowres_input() and forward() to mode="nearest". This keeps the tutorial flow intact while you investigate backend operator support.
Once the end-to-end example works, apply the same flow to your own model.
If you don’t have a workflow or model, you can skip this section and proceed to the next page.
If you already have a trained model, this is the minimal PTQ-to-.vgf flow. Start from your FP32 PyTorch module (model_fp32) and an example_input tuple that matches your real inference inputs. You also need a list of representative calibration_batches, typically 100–500 samples.
import torch
TOSAQuantizer,
from torchao.quantization.pt2e.quantize_pt2e import convert_pt2e, prepare_pt2e
def export_vgf_int8_ptq(
model_fp32: torch.nn.Module,
example_input: tuple[torch.Tensor, ...],
calibration_batches: list[torch.Tensor],
output_dir: str,
tosa_spec: str = "TOSA-1.00+INT",
model_fp32 = model_fp32.to("cpu")
model_fp32.eval()
exported = torch.export.export(model_fp32, example_input, strict=True).module(check_guards=False)
q = prepare_pt2e(exported, quantizer)
for x in calibration_batches:
q(x)
q = convert_pt2e(q)
aten_dialect = torch.export.export(q, args=example_input, strict=True)
vgf_partitioner = VgfPartitioner(compile_spec.dump_intermediate_artifacts_to(output_dir))
When you use your own model, the most important input is the calibration set. Treat it like a contract: if it doesn’t look like your actual inference data, PTQ quality can degrade.
In this section, you:
.vgf artifact using the ExecuTorch Arm backendIn the next section, you repeat the workflow using QAT, which gives the model a chance to adapt to quantization during fine-tuning.
