You can use ExecuTorch for running PyTorch models on constrained devices like mobile. As so many models are developed in PyTorch, this is a useful way to quickly deploy them to mobile devices, without the requirement for conversion tools such as Google’s ai-edge-torch to convert them into tflite.
To get started on ExecuTorch, you can follow the instructions on the PyTorch website . To then deploy on Android, you can also find instructions on the Pytorch website . If you do not already have ExecuTorch running on Android, follow these instructions first.
ExecuTorch comes with a set of profiling tools, but currently they are aimed at Linux, and not Android. The ExecuTorch profiling instructions for Linux can be adapted for use on Android.
To profile on Android, the steps are the same as for Linux , except that you need to generate the ETDump file on an Android device.
To start, generate the ETRecord in exactly the same way as described for the Linux instructions.
Next, follow the instructions to create the ExecuTorch bundled program that you will need to generate the ETDump. You will copy this to your Android device together with the runner program that you are about to compile.
To compile the runner program, you will need to adapt the build_example_runner.sh script in the instructions that are located in the examples/devtools subfolder of the ExecuTorch repository to compile it for Android. Copy the script and rename the file to build_android_example_runner.sh, ready for editing. Remove all lines with coreml in them, and the options dependent on it, as these are not needed for Android.
You then need to set the ANDROID_NDK environment variable to point to your Android NDK installation.
At the top of the main() function add:
export ANDROID_NDK=~/Android/Sdk/ndk/28.0.12674087 # replace this with the correct path for your NDK installation
export ANDROID_ABI=arm64-v8a
Next, add Android options to the first cmake configuration line in main(), that configures the building of the ExecuTorch library.
Change it to:
cmake -DCMAKE_INSTALL_PREFIX=cmake-out \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_TOOLCHAIN_FILE="${ANDROID_NDK}/build/cmake/android.toolchain.cmake" \
-DANDROID_ABI="${ANDROID_ABI}" \
-DEXECUTORCH_BUILD_XNNPACK=ON \
-DEXECUTORCH_BUILD_EXTENSION_DATA_LOADER=ON \
-DEXECUTORCH_BUILD_EXTENSION_MODULE=ON \
-DEXECUTORCH_BUILD_EXTENSION_RUNNER_UTIL=ON \
-DEXECUTORCH_BUILD_EXTENSION_TENSOR=ON \
-DEXECUTORCH_BUILD_DEVTOOLS=ON \
-DEXECUTORCH_ENABLE_EVENT_TRACER=ON \
-Bcmake-out .
The cmake build step for the ExecuTorch library stays the same, as do the next lines setting up local variables.
Next you will adapt the options to Android in the second cmake configuration line, which is the one that configures the building of the runner.
Change it to:
cmake -DCMAKE_PREFIX_PATH="${cmake_prefix_path}" \
-Dexecutorch_DIR="${PWD}/cmake-out/lib/cmake/ExecuTorch" -Dgflags_DIR="${PWD}/cmake-out/third-party/gflags" \
-B"${build_dir}" \
"${example_dir}"
Once you have changed the configuration lines, you can now run the script ./build_android_example_runner.sh to build the runner program.
Once compiled, find the executable example_runner in cmake-out/examples/devtools/.
Copy example_runner and the ExecuTorch bundled program to your Android device.
Do this with adb:
adb push example_runner /data/local/tmp/
adb push bundled_program.bp /data/local/tmp/
adb shell
chmod 777 /data/local/tmp/example_runner
./example_runner --bundled_program_path="bundled_program.bp"
exit
adb pull /data/local/tmp/etdump.etdp .
You now have the ETDump file ready to analyze with an ExecuTorch Inspector, in line with the Linux instructions.
To get a full display of the operators and their timings, use the following:
from executorch.devtools import Inspector
etrecord_path = "etrecord.bin"
etdump_path = "etdump.etdp"
inspector = Inspector(etdump_path=etdump_path, etrecord=etrecord_path)
inspector.print_data_tabular()
However, as the
ExecuTorch profiling page
explains, there are data analysis options available. These enable you to quickly find specified criteria such as the slowest layer or group operators. Both the EventBlock and DataFrame approaches work well. However, at time of writing, the find_total_for_module() function has a
bug
and returns incorrect values - hopefully this will soon be fixed.
