Prepare models for neural graphics with Arm neural technology
Set up your environment
Create a reference model
Export the reference model with the ExecuTorch VGF backend
Inspect the model in Model Explorer
Inspect TOSA artifacts
Start with a small model
Before using a production NSS model, it helps to validate the toolchain with a small graph that is easy to inspect.
In this section, you’ll use a minimal AddSigmoid model so you can focus on the conversion flow:
- PyTorch export
- VGF export with the ExecuTorch backend
- Artifact inspection in Model Explorer
- Optional TOSA inspection when you need to debug the lowering path
- Runtime validation with an ExecuTorch runner
Neural graphics models sit between ML tooling and real-time graphics runtimes. In Arm’s neural accelerator ecosystem, a trained PyTorch model usually needs to become a deployable artifact that can be consumed by ML Extensions for Vulkan. It then needs to be inspected with graphics-oriented tooling and validated before it is integrated into an engine or sample application.
This is the same workflow pattern used in other NX Learning Paths, including Quantize neural upscaling models with ExecuTorch and Fine-tune neural graphics models using Model Gym .
Create and export an AddSigmoid model
Create a Python file named create_reference_model.py:
import torch
class AddSigmoid(torch.nn.Module):
def __init__(self):
super().__init__()
self.sigmoid = torch.nn.Sigmoid()
def forward(self, x: torch.Tensor, y: torch.Tensor) -> torch.Tensor:
return self.sigmoid(x + y)
example_inputs = (torch.ones(1, 1, 1, 1), torch.ones(1, 1, 1, 1))
model = AddSigmoid().eval()
exported_model = torch.export.export(model, example_inputs)
graph_module = exported_model.module(check_guards=False)
_ = graph_module.print_readable()
torch.export.save(exported_model, "add_sigmoid.pt2")
print("Wrote: add_sigmoid.pt2")
Run the script:
python create_reference_model.py
The printed graph confirms the model was exported correctly. The saved add_sigmoid.pt2 file is the input to the backend lowering steps that follow.
You’ve now created and exported a minimal AddSigmoid PyTorch model that you’ll use to validate the model preparation workflow.
Next, you’ll export this model with the ExecuTorch VGF backend.
