Prepare models for neural graphics with Arm neural technology
Set up your environment
Create a reference model
Export the reference model with the ExecuTorch VGF backend
Inspect the model in Model Explorer
Inspect TOSA artifacts
Prepare your host system
Before you can create a reference PyTorch model, you need to set up Python, ExecuTorch, and Arm backend dependencies.
Use one of the following:
- Linux
- macOS with Apple Silicon
Verify that your Python version is 3.10 or later and earlier than 3.14:
python3 --version
Create a Python virtual environment
Create a working directory for this Learning Path:
mkdir preparing-models-for-nt
cd preparing-models-for-nt
Create a virtual environment:
python3 -m venv venv
source venv/bin/activate
python -m pip install --upgrade pip
Clone and install ExecuTorch
Clone ExecuTorch from GitHub and install:
git clone https://github.com/pytorch/executorch.git repo/executorch
cd repo/executorch
./install_executorch.sh
Install Arm backend dependencies
From the root of repo/executorch, run:
./examples/arm/setup.sh \
--i-agree-to-the-contained-eula \
--disable-ethos-u-deps \
--enable-mlsdk-deps
Source the generated path script in the same shell session:
source ./examples/arm/arm-scratch/setup_path.sh
Return to the Learning Path working directory:
cd ../..
(Optional) Use a Jupyter notebook
If you prefer to work through the same steps in Jupyter, download the notebook from the arm-learning-paths repository:
wget https://raw.githubusercontent.com/ArmDeveloperEcosystem/arm-learning-paths/main/content/learning-paths/mobile-graphics-and-gaming/preparing-models-for-nt/prepare-models-for-nt.ipynb
Install Jupyter Lab in your active virtual environment:
pip install jupyterlab
From the preparing-models-for-nt directory, launch Jupyter Lab:
jupyter lab
Open the notebook:
You’ve now set up the Python environment, installed ExecuTorch, and configured Arm backend dependencies for creating and exporting PyTorch models.
Next, you’ll create and export your first test model, either from the Learning Path pages or from the optional Jupyter notebook.
