To run this on an Android device, you need to cross-compile ONNX Runtime using the Android NDK.
Before you begin, verify that you have:
First, clone the
ONNX Runtime
. This Learning Path uses version v1.23.2:
git clone https://github.com/microsoft/onnxruntime.git onnxruntime.git
cd onnxruntime.git/
git checkout v1.23.2
Build ONNX Runtime with KleidiAI support enabled. The build script configures cross-compilation for Android arm64-v8a, enables shared library output, and activates KleidiAI integration through the onnxruntime_USE_KLEIDIAI=ON flag. Run the following from the root of the ONNX Runtime repository (the onnxruntime.git/ directory from the previous command):
./build.sh --android --android_sdk_path $ANDROID_NDK_HOME --android_ndk_path $ANDROID_NDK_HOME --android_abi arm64-v8a --android_api 27 --config RelWithDebInfo --build_shared_lib --cmake_extra_defines onnxruntime_USE_KLEIDIAI=ON --cmake_generator Ninja --parallel
onnxruntime_USE_KLEIDIAI=ON triggers the inclusion of Arm KleidiAI kernels into the MLAS library.build/ by default. This can be overridden with the --build_dir <path_to_your_build_directory> command line option to build.sh.Once the build is complete, you will find the libonnxruntime.so shared library and onnxruntime_perf_test binary in your build directory.
onnxruntime_perf_test is essential for measuring latency and identifying bottlenecks of an ONNX model (named <your_model>.onnx hereafter). Note that onnxruntime_perf_test expects the ONNX model to come with some ancillary files organized in some directory tree (input data for example).
Transfer the benchmark binary and shared library to your Android device:
adb push <build_dir>/Android/RelWithDebInfo/onnxruntime_perf_test /data/local/tmp/
adb push <build_dir>/Android/RelWithDebInfo/libonnxruntime.so /data/local/tmp/
The onnxruntime_perf_test tool simulates inference and gathers statistics. Run a benchmark with 20 iterations:
# Execute on the device
adb shell "/data/local/tmp/onnxruntime_perf_test -e cpu -m times -r 20 -s -Z -x 1 /data/local/tmp/<your_model>/<your_model>.onnx"
The benchmark command uses several flags to control execution:
-e cpu: Use the CPU execution provider-m times: Run in timing mode to measure latency-r 20: Repeat the test 20 times for consistent results-Z: Prevent thread spinning to reduce CPU usage-s: Display statistics after the run-x 1: Use a single thread for parallel execution within nodesYou can adjust these settings based on your performance testing needs.
To see exactly how many milliseconds each operator consumes, use the profiling flag -p. This generates a JSON trace file:
adb shell "/data/local/tmp/onnxruntime_perf_test -p /data/local/tmp/profile.json -e cpu -m times -r 5 -s -Z -x 1 /data/local/tmp/<your model>/<your_model>.onnx"
adb pull /data/local/tmp/profile.json
The -p flag enables performance profiling during the benchmark run. When you provide this flag followed by a filename, ONNX Runtime generates a JSON file containing a detailed trace of model execution.
You can view the results by opening perfetto tool and loading the generated JSON file. This shows a visual timeline of which operations took the most time. You can also convert the JSON file to a CSV sheet by creating a Python script.
