In this section, you set up a GCC cross-compile toolchain and build a statically linked llama-cli binary with KleidiAI and SME2 enabled.
For convenience, llama.cpp is statically linked. You use the aarch64 GCC cross compile toolchain, aarch64-none-linux-gnu-, to build the project. To support SME2, GCC compiler version 14.2 or later is required.
The build uses the Linux-hosted Arm GNU Toolchain. If you are working on macOS or Windows, run these commands in a Linux environment (for example, a Linux VM, container, or a Linux development machine).
Start by downloading and unpacking the Arm GNU Toolchain (GCC 14.2) for your host architecture:
TOOLCHAIN_VER="14.2.rel1"
mkdir -p "$HOME/toolchains" && cd "$HOME/toolchains"
HOST_ARCH="$(uname -m)"
if [ "$HOST_ARCH" = "x86_64" ]; then
TOOLCHAIN_TAR="arm-gnu-toolchain-${TOOLCHAIN_VER}-x86_64-aarch64-none-linux-gnu.tar.xz"
elif [ "$HOST_ARCH" = "aarch64" ]; then
TOOLCHAIN_TAR="arm-gnu-toolchain-${TOOLCHAIN_VER}-aarch64-aarch64-none-linux-gnu.tar.xz"
else
echo "Unsupported host architecture: $HOST_ARCH" >&2
exit 1
fi
curl -L -O "https://developer.arm.com/-/media/Files/downloads/gnu/${TOOLCHAIN_VER}/binrel/${TOOLCHAIN_TAR}"
tar -xf "${TOOLCHAIN_TAR}"
export PATH="$PWD/${TOOLCHAIN_TAR%.tar.xz}/bin:$PATH"
Confirm the installation succeeded by printing the compiler version:
aarch64-none-linux-gnu-gcc --version
This Learning Path uses llama.cpp tag b7610. Newer versions should also work but are not tested.
Download the llama.cpp source code and check out that tag:
cd $HOME
git clone --depth 1 --branch b7610 https://github.com/ggml-org/llama.cpp.git
Create a new build directory under the llama.cpp root directory and change to it:
cd $HOME/llama.cpp
mkdir build && cd build
Configure the project. The key flags enable KleidiAI support (-DGGML_CPU_KLEIDIAI=ON) and SME2 instructions (-march=...+sme2), produce a statically linked binary (-static) that runs across Android and Linux environments, and include debug symbols (-g) for profiling:
cmake .. \
-DCMAKE_SYSTEM_NAME=Linux \
-DCMAKE_SYSTEM_PROCESSOR=arm \
-DCMAKE_C_COMPILER=aarch64-none-linux-gnu-gcc \
-DCMAKE_CXX_COMPILER=aarch64-none-linux-gnu-g++ \
-DLLAMA_NATIVE=OFF \
-DLLAMA_F16C=OFF \
-DLLAMA_GEMM_ARM=ON \
-DBUILD_SHARED_LIBS=OFF \
-DCMAKE_EXE_LINKER_FLAGS="-static -g" \
-DGGML_OPENMP=OFF \
-DCMAKE_C_FLAGS=" -march=armv8.7-a+sve+i8mm+dotprod+sme2 -g" \
-DCMAKE_CXX_FLAGS=" -march=armv8.7-a+sve+i8mm+dotprod+sme2 -g" \
-DLLAMA_BUILD_TESTS=OFF \
-DLLAMA_BUILD_EXAMPLES=ON \
-DLLAMA_CURL=OFF \
Set CMAKE_C_COMPILER and CMAKE_CXX_COMPILER to your cross compiler path if it is not already in your PATH. Make sure that -march in CMAKE_C_FLAGS and CMAKE_CXX_FLAGS includes +sme2.
The -static and -g options are specified to produce a statically linked executable, in order to run on different Arm64 Linux/Android environments and include debug information.
Build the project:
cd $HOME/llama.cpp/build
cmake --build ./ --config Release -j $(nproc)
After the build completes, confirm that llama-cli exists in the binary directory:
ls -la $HOME/llama.cpp/build/bin | grep llama-cli
In this section:
llama-cli binary with KleidiAI and SME2 enabled, ready to run on your Android targetIn the next section, you’ll transfer the binary and model to the device and compare inference performance with SME2 on and off.
