Give feedback
AI-assisted
Close
Which compiler and toolchain should I use to build with SME2?
Use the aarch64 GCC cross-compile toolchain with the aarch64-none-linux-gnu- prefix from the Linux-hosted Arm GNU Toolchain. You need GCC version 14.2 or later to enable SME2.
Why do I need a Linux host to build llama.cpp?
The build uses the Linux-hosted Arm GNU Toolchain. If you work on macOS or Windows, run the commands in a Linux virtual machine, container, or development machine.
What files must be on the Android device before measuring performance?
Place the built llama-cli executable and the Llama-3.2-3B-Instruct-Q4_0.gguf model on the device.
How do I verify that the SME2 path is used during inference?
Follow the verification step that confirms SME2 microkernels are active. The ggml-cpu backend selects KleidiAI SME2 microkernels when the hardware supports them.
How should I compare runs with SME2 enabled and disabled?
Run the model on the Android device twice — once with SME2 enabled and once with it disabled. Compare the performance reported by llama.cpp from both runs.
Return to Mobile, Graphics, and Gaming
