Evaluate Opacity Micromaps for ray-traced game assets
Decide if an asset needs OMM
Choose an OMM representation
Connect OMM to Arm Mali G2-Ultra NX
Build and validate an OMM adoption plan
Use OMM to let ray traversal resolve known opaque and transparent regions of an alpha-tested asset. With OMM, you can reduce repeated shader-side opacity checks when rays pass through assets such as foliage or fences.
Start with alpha-tested assets that participate in ray tracing, have stable opacity masks, and receive repeated ray hits. You’ll need an update policy for changing masks, while alpha-blended and rasterization-only assets belong on their existing paths.
No. You can work through asset decision and validation with the provided bake results and saved device capability report. If you have an Arm Mali G2-Ultra NX device, you can compare its reported capabilities with your chosen OMM strategy.
No. You keep the original mesh triangles and use OMM to describe opacity in smaller regions within them. You don’t add polygons to the source model.
Compare image quality with and without OMM, then check the asset’s data cost and remaining shader-side work against your goals. You can use the Learning Path’s sample evidence to practice that decision before testing it in your own renderer.
