Explore related resources
Give feedback
AI-assisted
Close
How do I know NSS is active in my level?
Run ShowFlag.VisualizeTemporalUpscaler 1 in Unreal and check the rendering summary. You should see NSS listed. To hide the overview, run ShowFlag.VisualizeTemporalUpscaler 0.
Which Unreal Engine project template should I use for the example?
Create a new Third Person template project using the C++ option. Open it in Visual Studio and build from source before enabling and running NSS.
How do I set up the ML emulation layers for Vulkan?
For Unreal Engine 5.4 or 5.6, install Vulkan SDK version 1.4.321.0 or later, then run the plugin’s DownloadEmulationLayer.bat script. Use Vulkan Configurator to enable the downloaded Graph and Tensor layers. For Unreal Engine 4.27, follow its separate plugin README.
How can I visualize the NSS model output while the game runs?
Run the command r.NSS.Debug 1 in Unreal. The command adds real-time views showing the model output to help you inspect results.
When should I use RenderDoc?
Use RenderDoc when you see unexpected visual output or need to analyze a frame in detail. RenderDoc lets you step through a capture, inspect Vulkan API calls, and review shader inputs and outputs, with additional features available for Arm GPUs.
Return to Mobile, Graphics, and Gaming
